Shifter problem? maybe?
Old Feb 25, 2008 | 08:27 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Last time I went to the track I overshot the shift into 2nd gear and went into 3rd not knowing it until I was watching the Tach and it shifted at 4600 rpms.....It only does it on the shift from First to Second
anyways....it didnt get any better and i am replacing the transmission bc i blew it up......i have a Formula so a megashifter would require alot of fabrication and prety much any aftermarket shifter would. Is there something wrong with the shifter or is it the cable?
Old Feb 26, 2008 | 09:27 PM
Car: 92 Camaro
Axle/Gears: S60 373
Re: Shifter problem? maybe?
nobody?
Old Feb 27, 2008 | 03:25 AM
Pat Hall's Avatar
Hard to say for sure really. I would probably lean more towards it being the cable. It might be slightly out of adjustment to where it barely stays in 1st. Of course that's the beauty of the aftermarket shifters, in the fact that they have positive stops for each gear. But like you said, with a Formula, it's a pretty significant PITA to modify the console/shift plate to accomodate a ratchet shifter. It has been done though. Try searching. I remember a post some time ago with pictures where a guy put one in his Formula.
Old Feb 27, 2008 | 11:09 AM
Car: 92 Camaro
Axle/Gears: S60 373
Ill try the cheaper route---replacing the cable first.....if thats not it then ill just have to be very careful when racing
thanks Pat
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
neekolzun
Aug 24, 2015 04:59 PM
