4th gen posi in a 3rd gen rear possible?
Car: 1986 T/A,91 Firebird
Engine: LG4 305, 3.1 V6
Transmission: TH700-R4 x2
Axle/Gears: 2.73,3.23
got an 86 T/A. got a chance to buy a Torsen posi with 3.73 gears, Ive got the 2.73's now and no posi.
Will it work or not? or what parts will I need to get it to work?
Car: 1990 Iroc
Re: 4th gen posi in a 3rd gen rear possible?
It will work. I bought one from slp about two years ago that was taken out when new. It droped right in.
Car: '84 Camaro
Engine: 5.3l TSP 224r
Transmission: TH350 3600 stall
Axle/Gears: LS1 3.23
It will most likely just bolt right in, but you'll need 28 spline axles. Your axles are 26 spline.
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You will need to change out to the 88 (or is it 89?) and newer 28 spline axle shafts to run the 4th gen rear. Other than that, it's a bolt in swap.
Car: 1987 Pontiac T/A GTA
Engine: 350ci 5.7 liter
Transmission: Stock GTA Tranny
I just finished the intall on my 4th gen rear to my 87 GTA the only thing is that it only burns 1 tire sumtimes but then it will burn both other times anybody kno why it would do this???? it from a 95 Z28 with the LT1 and automatic trans also what size it the rear off the 95 z28 a 7.5" or 8.5" etc
Thanks in advance
Thanks in advance
thanks for the replies I'll have to see what I can find in axles
Car: '84 Camaro
Thanks in advance
Thanks in advance
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
There should have been a small metal tag attached to one of the bolts that holds the rear end cover to the axle. If it said use LSD addative then yes, or if it is a GM limited slip rear end then yes. I know on the LS car it's a lube of LSD addative and 75w140 synthetic gear oil. Not sure about the LT1 axles though. Just call a dealer if you are unsure what should be in there.
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
