Flashing the converter?
Old Mar 6, 2008 | 10:00 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I can no longer foot brake my car. I have a 2900 vigilante lock up converter. Can someone tell me what flashing the converter is, and how to do it. i am lost and have no idea what to do?
Old Mar 8, 2008 | 01:06 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: Flashing the converter?
BUMP
Old Mar 10, 2008 | 01:56 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Flash stall is when you smash the gas to wot at a dead stop. Your flash stall will generally be higher than the advertised stall.
Get some better brakes or install a trans brake.
Oh and dont stall converter and let off the gas, thats bad for a lot of parts. Rpms drop too quick. Stall the converter and take off.
Old Mar 10, 2008 | 04:51 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
They don't make trans brakes for the 700r4, and i heard if they did they would not last long
Old Mar 10, 2008 | 05:49 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Probably not. How high can you stall it until the car breaks free?
Old Mar 27, 2008 | 08:42 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
1000 rpm
Old Mar 27, 2008 | 09:33 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The cam you are using.... provide enough vacuum for power brakes to work correctly?
Old Mar 28, 2008 | 10:04 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
it should its a brand new zz409
junior419
Apr 7, 2025 11:35 AM
84LsxZ28
May 17, 2020 02:21 PM
customblackbird
Oct 1, 2015 04:30 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
