need help quick guys
Old Mar 16, 2008 | 07:47 AM
Unholy 89's Avatar
Car: '89 5spd GTA
Engine: 305(LB9) TPI
Axle/Gears: Borg-Warner 3.42
changing my clutch and just let down the bellhousing and there is a line at the top. small black line with white fitting on top, other end goes into the t5 near the shifter. any ideas?
Old Mar 16, 2008 | 09:48 AM
Re: need help quick guys
any ideas?
No; sorry. No ideas.
Only facts.
It's the vent. Earier T-5s just had a little white plastic plug mounted in the top of the trans.
Old Mar 16, 2008 | 10:25 AM
Unholy 89's Avatar
Car: '89 5spd GTA
you're the man sk, I was hoping that was the case. this place is thebest.
Have you ever changed a t5 on the floor, no lift, only stands
If so, did you remove the clutch housing seperate or all with the tranny. I pulled mine together and now worried about getting back in and lining up everything. freakin body is soo low
Old Mar 16, 2008 | 10:32 AM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
i have... its a pain! save your back and neck and install clutch assem.,bellhousing, then tranny.oh, did you change your pilot bushing?
Old Mar 16, 2008 | 10:39 AM
Unholy 89's Avatar
Car: '89 5spd GTA
yep..i did....and yep...its a pain
Old Mar 16, 2008 | 11:18 AM
Many, many, many, many times. I had it down to where I could do a complete T-5 R&R in about 2½-3 hours, from drive-in to drive-out. It's fastest with 3 pairs of jack stands and a floor jack.
The T-5 is about the lightest manual transmission there is in a V8 car. As such things go, it's pretty easy, really.
Easiest to pull the trans first, then the BH; and reassmeble the same way. The T-5 weighs so little, you can stab it up in there and then hold it with one hand while starting bolts with the other. Whatever you do, DO NOT let the trans hang its weight on the clutch without support; and DO NOT use the bolts to "draw" the trans up to the BH, make sure it goes all the way in BEFORE tightening the bolts.
Old Mar 16, 2008 | 03:33 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Ok, Sofa, since I'm a scrawny little pup, I want pictures of those Popeye (the Sailor Man) forearms of yours .
JamesC
Old Mar 16, 2008 | 06:21 PM
I wish!!!
d00d, I'm 6'1" tall, and weigh 135 lbs. I would be the PERFECT 140-lb weakling, except that one of those is BIGGER than me, I'm even scrawnier and weaker than that!!!
If I can do it, ANYBODY can.
Old Mar 16, 2008 | 08:07 PM
Unholy 89's Avatar
Car: '89 5spd GTA
Alright guys, tranny is in and underneath all done...all I have to do now is dump new fluid in. BTW--I'm guessing I pour it in the shifter location, right?
I see the check plug midways up on the tranny and the drain on the bottom. Checked the drain and she was bone dry. A lot came out during my fumbling on disassembly. My Haynes book says 3.5pints, sound right? Using TCI Auto tranny fluid? So far the clutch feels good, but I have not started her.
Also, my one blunder that I know of was that I forgot to put the fork boot back on. tried to split it and get it on but no luck and I'm not pullin it all apart again for it.
Old Mar 16, 2008 | 10:14 PM
Yup, you can do it that way; or, through the fill plug, on the PASS SIDE of the trans.
DO NOT take out the bolt looking thing on the driver's side that looks like a plug!!!!
3.5 pints = 1¾ quarts
Sounds like not quite "full", but probably enough... seems like if you add until it reaches the fill plug, it ends up taking more than 2 quarts. But I haven't messed with a T-5 for a while, so my memory could be off.
That kind of fluid, or any other ATF, is fine.
Jorlain
Aug 24, 2022 05:11 PM
Infested
May 22, 2018 11:56 PM
crazynights
Aug 21, 2015 06:53 AM
happyhapka
Aug 15, 2015 04:42 PM
Street Lethal
Aug 14, 2015 08:25 PM
