Ordering 9 inch housing, I have questions
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I will be ordering a 9 inch housing soon. I have a few questions before I order. I have a third member from an early 70s pickup. It has 31 splines, so that aspect is covered. I will be running my factory brakes, but I will be using 4th gen backing plates in place of the thirdgen ones. What should I lookout for in respect to my brakes? What about the torque arm? It is the Jegster unit. What else should I be aware of? Where is the cheapest place to order from? Should I get a housing or a housing and axle package?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Ordering 9 inch housing, I have questions
Housing and axle package. Tell them what brakes you'll be using so they put the proper ends on the axle tubes.
Car: 1990 Formula
Engine: 95 LT1
Kind of what I figured. Where is the cheapest place to get the package? I wish I had bought one a few years ago. The prices seem to have jumped a couple hundred dollars since then.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Exotic Performance has the best prices i have found, i believe you can buy just the housing/axles from them.
Car: 1990 Formula
Engine: 95 LT1
I will check that out. I just want to have all my bases covered before I order. I want to have as little downtime as possible with my car.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
www.exoticperformanceplus.com
talk to bob.....tell him you seen xpndbl3's assembly guide on his website too
I do not believe that the thirdgen backing plates will work at all, you need to buy some LT1 backing plates and run the LT1 discs, which would be the same rotor and caliper as the PBR brakes I "think", but you need the 4th gen backing plates to put on the rear. I bought mine from ebay.
Car: 1990 Formula
Engine: 95 LT1
I will actually be using the 4th gen backing plates. Mainly because I have a set that are already off. I saw their site, but I was confused because it didn't list and brake options. The prices are about the same as Spohn's. Did you have to modify the backing plates for them to fit?
Car: 1990 Formula
Engine: 95 LT1
xpndbl3, I looked at your site. That is pretty much what I am going for. I also have the jegster torque arm. I am going to try to find your guide and go over it. I remember reading it when I started searching for info.
1992 Trans Am
May 10, 2023 07:19 PM
