Clutch fork Question
Old Mar 24, 2008 | 09:32 PM
larryz28's Avatar
Car: 82 Z28
After a T5 swap, on my 82 Z28, the piston coming out of the slave unit to operate the clutch fork is a 30 degree angle into the recess on the clutch fork. The clutch fork looks too long. Is this normal?? I do not have anything to compare to and do not know if the clutch fork is the right one. Any help on this subject would be great.
Old Mar 24, 2008 | 10:09 PM
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
Re: Clutch fork Question
Did you hook the clutch fork onto the pivot ball inside the bell housing? My T5s always had the piston out of the slave fairly straight, nowhere near a 30 degree angle.
Old Mar 25, 2008 | 07:03 AM
larryz28's Avatar
Car: 82 Z28
Thanks, that is what I thought. The clutch fork is in the ball. I have driven the car two two seasons now. But I have the T5 out for reapirs, and the slave unit did not look right. This would be time to fix it right. I guess I will need to find another clutch fork and see if there is a difference. Thanks. PS know anybody who has an extra clutch fork??
Old Mar 25, 2008 | 07:36 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
the clutch ball pivot studs have been known to back out . ( happened to me ) they can be tightened with tranny installed ( PITA , but possible ) be sure to clean and use locktite . worst case would be T/O bearing installed wrong on clutch fork . i think sofa recently posted pics. of throw out bearing installation . possible problem ?? good luck .
Old Mar 25, 2008 | 07:51 AM
larryz28's Avatar
Car: 82 Z28
Tanny is currently out of the car. Clutch worked fine, just did not look right. I only drive the car in the summer 1,000 - 1,800 miles per year. Thought if I needed to rreplace now would be a good time. Thanks
Old Mar 26, 2008 | 04:49 AM
Pat Hall's Avatar
Here's an ebay link for the correct, hydraulic clutch fork. Price is really good too. http://cgi.ebay.com/ebaymotors/Clutc...mZ260200412542
Old Mar 26, 2008 | 09:10 AM
larryz28's Avatar
Car: 82 Z28
Thanks..bidding on it now..
Old Mar 27, 2008 | 02:19 AM
Pat Hall's Avatar
Glad to help.
Ghettobird52
Apr 21, 2020 08:44 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
rsrmoore
Aug 7, 2015 08:44 PM
