need help! can't find the rubber replacement bushing for my trans crossmember
i figured i could walk into the auto store and they would know, but just cause its me, i was wrong. i can't find the bushing anywhere and it does't shopw up on their computers. has anyone ever repaced these, i'm almost fed up and about to weld it into one solid piece.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: need help! can't find the rubber replacement bushing for my trans crossmember
It's called a transmission mount according to any parts store.
Car: '02 Z06
Engine: L33 5.7
summit racing sells one made by energy suspension that is polyurethane.
And it should never break again. The cheap rubber replacements from auto stores go out way to quick.
http://store.summitracing.com/partde...5&autoview=sku
is this the part they keep showing you?
If that is not it, perhaps it is the torque arm bushing you need?
Torque arm bushing
Their are two part numbers depending on the year.
Torque arm bushing
i have that already. the bushings i need are round . it goes crossmember ,bushing, braket for trans mount, and another bushing on top.
oh and by the way, its an 85 iroc z
Last edited by tripingeorge3; Mar 31, 2008 at 04:19 PM. Reason: Automerged Doublepost
Car: '02 Z06
Engine: L33 5.7
I am really familiar with these portions of the thirdgens and it sounds like you do need that transmission mount, and perhaps what you are seeing is utterly destroyed and doesnt look anything like it used to.
Is this what you are looking at? this is a stock mount broken in two.
i bought and install the poly trans mount , have the torque arm bushing. my trans mount doesn't connect directly to the crossmember, there's another bracket on top of the crossmember that sits on rubber bushings, probably because the iroc z's were made sitting lower to the ground . almost seems like rubber spacers
Car: '02 Z06
Engine: L33 5.7
I have never heard anything of this before, COuld you by chance believe this was done by someone else for other reasons? I own an Iroc, I have owned an RS and a Base coupe as well, I have worked on many friends cars underneath and Never seen this. Perhaps someone did it to help drivetrain geometry? Does it look like you could just ditch those rubber mounts/spacers, and run just the mount, as intended?
can't. let me take a picture of it. there's a big molded hole there.it can't bolt directly to the crossmember. if u take yours where it bolts up, cut out about a fou=ot of that , raise it and connect it to the crossmember via bushings, that what i have.the crossmember is one piece, with a second piece rasied with bushing and on that braket it has the hole for the trans mount.
Car: '02 Z06
Engine: L33 5.7
Yes, please take a picture. I will help you solve this!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Seconary cross member. Check the following link for a pic and info:
https://www.thirdgen.org/forums/hist...ss-member.html
I used poly for a while. However, I also purchased the rubber version from my GM dealer:
Insulator 547702 (2)
Cush 547704 (2)
The above numbers are still good at GMPartsDirect.
JamesC
Cush 547704 (2)
JamesC
Yep, secondary cross member (as above).
JamesC
JamesC
Car: '02 Z06
Engine: L33 5.7
Well I stand corrected and sorry for wasting your time, doubting you.
I had an 84 sport coupe, M5, and no secondary cross member on it either.
Well, Glad you have your answers now!
just came from parts store, bastards still don't know what i'm talking about even though i have the vehicle info that this part is on. they're saying its a dealer part. they're really pissing me off.
Car: Pair of 92 Z28s
Your not alone Traviz!
How about that, i have never seen that under a third gen before.
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
My '84 Z28 with 700r4 has what your talking about. I haven't found those in the auto parts stores around Houston either. Unfourtunatly it's something you will probably have to order. I got mine from scogin dickies, or sdpc, and it didn't take to long. You will need all 4 parts, 2 cushions and 2 isolators. Mine came packed isolators in one vac pac, cushions in another vac pac.
Last edited by dirtywhiteZ28; Mar 31, 2008 at 08:58 PM. Reason: add a little more info
Car: 83Z28 HO
Transmission: G Force 5 speed
Have you removed the old donuts yet? I suggest you do before you bother getting replacements. I found a lot of rust that fell out when I took mine apart.
It hides between the two donuts on the metal crossbrace on each side (you need 4 rubber donuts). My brace was so thinned out in that area, I went to a boneyard and got one without the secondary mount like the pic above. Just my experience with them.
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Right; I have / had that too (83 L69 car); but I have a T-56 now.
Incidentally, I slotted mine for the 2-bolt-up mount, in addition to the one-stud-down kind as these cars came with, back before there were poly mounts; some of the old 60s cars had an interlocking mount in that footprint, so that's what I first changed to, to fix the weenie POS that breaks all the time.
.JamesC
Axle/Gears: '01 3.42 10 bolt
one thing you can do that works good is swap to the regular type crossmember so that you can run the more common mount. my current RS had the set-up that you do and i swapped the one in from my totaled iroc. this way you can use the poly mount that traviz showed you and don't have to worry about it breaking gain
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
