Stuck governor on a 727 trans.
Old Apr 7, 2008 | 09:22 PM
kamala250's Avatar
I was informed by some transmission buliders that I can go 55 mph and try to jam the car into park for a second, then back down into gear to unstick governor. Supposedly the ratcheting of the parking pawl dislodges dirt from the governor. I don't think this is correct. Any help?
Old Apr 11, 2008 | 10:05 PM
billymac49's Avatar
Car: 88 IROC
Engine: 5.0 tpi
Transmission: 700 r4
Re: Stuck governor on a 727 trans.
i have heard about this never tried it. the dawgs on the output shaft are spinning too fast for the parking pawl to actually catch and engage park. i never had the guts to try this because what happens if they do catch (especially in a customers car). also i don't think that's the correct way to fix the problem. if you can't remove the gov. and free it up then then try another one.
Old Apr 12, 2008 | 12:03 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need to be an idiot if you believe that but you can destroy as many chrysler 727 transmissions as you want. They're not good for anything anyway. The 904 is the better one. That's about as good as reving up and engine to 5000 rpm and pulling the shifter from park to drive. It'll have about the same effect.
Old Apr 12, 2008 | 11:21 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Hey Stephen, just kinda curious as to why you think the 904 is better than the 727? They are both the same design. The 727 just has bigger internals than the 904. I'm not partial to either as i haven't seen a dodge design tranny that i do like.
Old Apr 12, 2008 | 11:49 AM
AlkyIROC's Avatar
Car: 87 IROC L98
I'm not a dodge person myself but I've seen a lot more 904's at the track than 727. Sort of like how a powerglide is more popular in a drag car than a TH350 or TH400
92projectcamaro
Dec 8, 2015 12:25 AM
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
HikoriYami
Sep 21, 2015 07:11 PM
ctoledo0834
Sep 18, 2015 04:16 PM
