how to pull t5 access panel?
Old Apr 8, 2008 | 08:45 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
well the title of the post explains it all the bell housing is off so are the shifter and access panel bolts you tell me the rest please
Old Apr 8, 2008 | 10:08 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: how to pull t5 access panel?
If you are referring to the top cover, it is not complicated but, it is not simple either. With the shifter off, you will need to pop out what looks like a cam plug on the tail side. Once inside you will see a steel block that the shifter sits in. There is a roll pin that needs to be pushed out so you can remove the block. Ater the block is removed you should be able to remove the tailshaft housing once all those bolts have been taken out by sliding it back far enough to clear the shifter rail. Once the housing is clear, the top cover should be free to come straight up(or a little to one side or the other). Take note of the pads on the shift forks. If damaged or missing, it won't shift rightand should probably be replaced any way. I'm sure I forgot a step some- where( it's been a long time since the last time), if Sofa is out there I'm sure he can fill in the blanks. hope this helps.
Old Apr 8, 2008 | 10:40 PM
mxcrazed's Avatar
Engine: None
Transmission: none
Well It doesn't look like you forgot anything all that looks like it will do it. I was afraid that I would have to remove the tail shaft casing should I reinstall it with rtv? can I use dextron 3?
Old Apr 8, 2008 | 11:10 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
you can use anaerobic(?)sealer or rtv. I've never had a problem with a Frod product for use on the 7.3 diesels. It is gray in color and sets up very quickly. As far as what fluid to use is up for debate but, AFAIK the dex3 should be one of the candidates.
Old Apr 9, 2008 | 08:24 AM
mxcrazed's Avatar
Engine: None
Transmission: none
Thank you for your help squirted.
wigmobile
Feb 26, 2025 02:56 PM
tattmann
Sep 27, 2015 05:20 PM
mrdevontay
Sep 2, 2015 08:04 PM
86IROC112
Aug 31, 2015 07:00 AM
Street Lethal
Aug 14, 2015 08:25 PM
