Can't Adjust T.V. Cable?
Old Apr 19, 2008 | 08:47 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
When I try to adjust my tv cable I cant get it to go right. I pull the slider all the way back and when I try to hook the cable to the throttle lever it wont reach it all the way. So then instead of doing it that way I leave it on the lever and then try to pull the cable all the way back. However the slider doesnt go all the way back and when I pull it to wide open throttle the slider comes all the way out before I even get to WOT. Aybody have any ideas of what might be wrong?
Old Apr 20, 2008 | 03:41 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Can't Adjust T.V. Cable?
any clues?
Old Apr 21, 2008 | 04:07 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Any ideas before I go out and buy a new one?
Old Apr 21, 2008 | 11:35 PM
squeeezer's Avatar
Car: 5 cars
sounds like a braket problem to mee
got pics?
http://www.tvmadeez.com/article/index.php
Old Apr 22, 2008 | 03:28 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Here is a picture of what the cable does when I open the throttle all of the way.
http://s214.photobucket.com/albums/c...t=DSC03106.jpg
Old Apr 23, 2008 | 09:18 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Does this look like a bracket issue or a cable issue?
Old Apr 24, 2008 | 12:10 AM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
i had the same problem when i put in a new trans. the cable i bought is made by teckpak, its has a different adjuster that doesnt slip. just google that and youll find it.
Old Apr 24, 2008 | 02:59 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
So pretty much I need to get a new cable?
Old Apr 24, 2008 | 10:54 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Also like I said, I cant slide the slider all the way back without unhooking the cable from the throttle lever. What is causing this?
Old May 31, 2008 | 10:03 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Old Jun 1, 2008 | 06:26 PM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
your cable is wrong. it's for the wrong motor. I got into it with advance auto parts over that. cause I know the guy and he knows it's a 350 he kept sending me a 350 tpi cable when I needed a 305 tbi cable
Old Jun 1, 2008 | 07:17 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I dont see how it can be the wrong cable since I took it with the 305 TPI motor that I put into my car.
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
