rearend making clunking noise
Old Apr 22, 2008 | 12:13 PM
85LT4Z28's Avatar
Car: 85 z28 and a 97 ford ranger
Engine: 305 carb and a 4cyl pos
Transmission: both have a 5spd
i have a 91 rs with 3:73 and a lsd now when i am letting off the gas it sounds like something is hitting the underside of my car... i put the car in my garage and put it up in the air. now i put it in drive and it was fine rev up the motor and you can hear a lot of noise coming from the rearend. so i pulled off the cover and replaced the fluid put the addative in and cleaned it out. now on the magnetic little piece i had a knot of metal shavings... so i put it back together and am still having the same noise the trans mount looks good... is there anything else i should check or does it sound like the lsd is toast... it is so frustrating please help...
Old Apr 23, 2008 | 03:00 PM
85LT4Z28's Avatar
Re: rearend making clunking noise
ok so i swapped out my drive shaft with one i had from one of my other camaros and put it in. while under there i put it in neutral and was moving it back and forth and noticed the same sound when i just barely turned it where the rear tires were not even moving and it sounds like it was coming from the trans... is there anything i can do to fix this... the other thing i noticed was that i can move the wheel back and forth before it starts to move the driveshaft... someone please help me i am loosing my mind...
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
86White_T/A305
Aug 17, 2015 12:16 AM
BlackBoulder
Aug 11, 2015 11:15 PM
BrianI
Aug 9, 2015 11:52 AM
