700R4 Lock up switch
Old May 4, 2008 | 07:55 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
https://www.thirdgen.org/torqueswitch
whats the advantage and disadvantage of this, i got a 2200 stall converter and my trans was custom built if it makes any diff.
i did to the temp hook up around the block to see what it was like, and it seemed pretty cool, but dont see how it can help my ET
Old May 4, 2008 | 08:31 PM
midwest's Avatar
Re: 700R4 Lock up switch
It works by locking up the converter. Under normal acceleration the input shaft of the transmission will be spinning around 500-700rpm( could be higher if you have a stall converter) less then what the flywheel is spinning. This mod gets rid of that lose of rpm. Ei more power will get to the wheels.
Old May 4, 2008 | 10:33 PM
89RS_82Z's Avatar
well you think its worth it, doing it like the link shows, im think the kits on jegs are for no CC cars right??
Old May 5, 2008 | 04:59 PM
89RS_82Z's Avatar
Ok, i played around with it enough to know i like having it, so im going to put a switch in, when should i lock it up, all the time, at the strip, in traffic, highway or when playing around???????
Old May 6, 2008 | 09:22 PM
89RS_82Z's Avatar
bump
Old May 7, 2008 | 08:44 PM
89RS_82Z's Avatar
with the unanswered ???
Old May 7, 2008 | 09:36 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
They got one on jegs?
I need one for a carbed car. How i go about doing that?
Old May 7, 2008 | 09:42 PM
89RS_82Z's Avatar
its in the catalog, under trans
or try
http://www.jegs.com/webapp/wcs/store...10733_-1_10529
Old May 8, 2008 | 09:18 PM
89RS_82Z's Avatar
GRRRRRR when should i lock it up, all the time, at the strip, in traffic, highway or when playing around???????
Old May 9, 2008 | 08:01 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
The torque converter provides torque multification. Not so sure locking it for perf reasons would really help. Maybe as your winding out 2nd or 3rd at the strip, engaging the clutch might help, a little, maybe.
The clutch is not designed to be engaged under high power situations. I suspect it wouldn't last long being subjected to such treatment.
You don't want the tranny changing gears with tc locked-up. That would be hard on the band and clutches.
If you come to a stop with tc locked, the eng will die (unless you shift to neutral).
IMHO, the only time it really provides a real advantage is when cruising down the road at around 45+ mph. In that condition it will save you some gas. Under cruise conditions, the computer should be engaging the TC clutch anyway.
Old May 9, 2008 | 09:30 PM
89RS_82Z's Avatar
ok, thats kinda what i was thinking
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
