What does a .500 boost valve feel like?
Old May 17, 2008 | 04:06 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
I've got a really simple question that i'm having a hard time getting a answer to.I've got a Sonnax .500 boost valve that i'm ready to install and would like to know just what i can expect it to 'feel' like.I know it increases line pressure to firm up shifts,but i've read different comments that the .500 boost valve is a race item and not needed for the street.I initially bought it to firm up my rather sluggish feeling shifts.The trans is still fairly fresh and i've already installed a corvette servo.I just want to hear from someone who put one in and it's effect on the shifts.Thanks in advance.
Old May 18, 2008 | 12:41 AM
Pro Built Automatics's Avatar
Re: What does a .500 boost valve feel like?
It will help raise line pressure across the board. It will firm up the shifts a little, depending on what size boost valve is in there now, and only in "D" or "OD" position. If you want to firm up the manual 1-2 shift, then you will need to add a .296 or .300 intermediate/reverse boost valve, as the .500" main boost valve does nothing here.
Old May 18, 2008 | 07:01 AM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Thanks for the reply Pro-built,my 1-2 shift feels pretty firm,but 2-3 kind of slides into gear.I didn't think a little more line pressure could hurt,i just didn't know if the .500 boost valve would be too much.I don't want it to slam into gear or anything.It sounds like a fairly subtle change.
Old May 18, 2008 | 10:19 AM
The Corvette servo will do more than the .500" boost valve, but I would do both, as the 2-3 shift slide is tearing up the 3-4 clutches. I carry these parts on my website.
Old May 18, 2008 | 01:23 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
I used to wonder the same thing as you. Do I go for the .471 or the .500 boost valve? Would the .471 be just right and the .500 too much?
.....I like the .500 valve. Feels very streetable. I took my mother for a ride and she didn't complain at all about the shift. (And she hates firm shifting cars)
Old May 18, 2008 | 03:17 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Thanks guys,thats just what i was looking for.I feel alot better about installing this badboy now..
Old May 18, 2008 | 09:30 PM
flyin89's Avatar
Make sure you get the snap ring all the way back up where it belongs. There is a first ring that a lot of people mistake for the snap ring groove when doing it while the trans is still in the car.
New2Chevy
Sep 28, 2015 12:35 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
86White_T/A305
Aug 17, 2015 12:16 AM
TreDeClaw
Aug 14, 2015 06:58 PM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
