What VSS for th2004r?
Old May 20, 2008 | 10:21 AM
j.a.s's Avatar
Engine: pontiac 400 -68
Transmission: th2004r
Axle/Gears: 10 bolt 3.08 gear open
Hello
I have a pontiac that i`m tbi converting. What vss should i use for this transmission? I would really need a gm part nr too.
The ECM is a 7747 (454ss)
Old May 20, 2008 | 10:41 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: What VSS for th2004r?
Found the links. Try looking here:
http://www.transmissioncenter.net/sp...____va.htm#200
http://tech.oldsgmail.com/speedo_gears.html
http://www.tciauto.com/Products/Tech...eedo_gears.asp
You'll find part numbers there too.
Have you tried Google, btw?
Lou
Old May 23, 2008 | 11:25 AM
j.a.s's Avatar
Hi again Lou
Yes i have been Googling on this problem
In the picture i have been able to identify a VSS that might work but i don`t know the GM number.
Hope somone does.
Old May 23, 2008 | 12:00 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
That is an aftermarket item. I think Painless has them.
Old May 25, 2008 | 01:21 AM
j.a.s's Avatar
Thanks for the answer.
I will look at what painless has.
//Joel
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
