2.73's stock?
Old May 22, 2008 | 06:57 PM
Jix01's Avatar
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
2.73's stock?
Ok so i have a 1990 firebird and i haven't took the diff cover off yet but i looked around and it seems that i have 2.73's?i don't know anything about gearing but i wanted to know if 2.73's are good or bad? i have noticed that it is pretty hard to burn off from a dead stop on dry pavement unless i really hammer on it but if i go around a corner it burns off pretty easy and its usually around 1600 rpms at 70 MPH.
Old May 22, 2008 | 07:18 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 2.73's stock?
2.73 is a fuel economy gear ratio, not a high-performance ratio. Typical performance gears for these cars are in the 3.42 to 4.10 range. A 2.73 rear end gear will make it harder to burn off the tires because there is less torque multiplication being made at the rear axle, so basically less power getting to the tires. The benefit though, is it keeps the RPMs way down at highway speeds, which helps fuel economy.
Old May 22, 2008 | 09:16 PM
Jix01's Avatar
Engine: 305 5.0 TBI
Re: 2.73's stock?
perfect, thanks alot
Old May 23, 2008 | 02:42 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Re: 2.73's stock?
Id go with 3.73's.
Old May 23, 2008 | 06:30 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Re: 2.73's stock?
Or compromise with a a 3.27 or 3.23.
Old May 25, 2008 | 01:29 AM
Jix01's Avatar
Engine: 305 5.0 TBI
Re: 2.73's stock?
well im still looking to get good gas mileage as this is my daily driver. not sure how much gearing will effect that.
Old May 25, 2008 | 06:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 2.73's stock?
Taller gears mean more RPM and RPM equals more fuel. With gas inching toward $4.00 a gallon....
JamesC
Old May 25, 2008 | 07:00 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: 2.73's stock?
If its NOT broke leave it alone. Unless you mod whats up front that gear change is not going to worth it just to burn the tires.
Old May 25, 2008 | 09:18 AM
Car: ws6
Engine: ls1
Transmission: m6
Re: 2.73's stock?
Well for performance a 2.73 rear is close to useless. It all depends on what he wants out of the car. For highway driving my 2.77's were great, but they sucked off the line. 3.45 gears made a HUGE difference in pick up, and I still get decent highway. I say if you want a good daily driver go with 3.42's. 3.73's if you plan on hitting up the track. Or just keep the 2.73's. Your call.
Old May 25, 2008 | 11:00 AM
Cadillac's Avatar
Re: 2.73's stock?
There is something to be said about cruising on the interstate at 85 MPH at only 2200 RPM. I also managed 28 MPG one trip after a tune up with the 2.73 "Unlimited Slipper".
Just sayin',
Old May 25, 2008 | 01:23 PM
Jix01's Avatar
Engine: 305 5.0 TBI
Re: 2.73's stock?
well i think il wait till i mod the engine a bit more . but hopefully gas goes down which it probably won't it is 4.08 for regular here lol
Old May 25, 2008 | 03:19 PM
Air_Adam's Avatar
Re: 2.73's stock?
How good it is on gas really depends mostly on where you drive - if its mostly highway, then the 2.73s would be a good gear to keep. If its mostly around town or at low speeds, then 2.73s might actually be hurting gas mileage (engine has to work harder to push the car at low speeds with that gear).
If its mostly around town, changing to a 3.23 or 3.42 gearset would probably improve fuel economy noticeably, as well as performance, but the offset would be that highway fuel economy would suffer somewhat. It would not be a huge drop in highway mileage, but probably would be noticeable.
Old May 25, 2008 | 05:54 PM
Jix01's Avatar
Engine: 305 5.0 TBI
Re: 2.73's stock?
so what kind of car would i be looking for to get 3.27's or 3.23's out of?or can i buy them? which is probably very expensive im guessing?lol
Old May 25, 2008 | 06:29 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: 2.73's stock?
I have a 350 TBI and I swapped from 2.73 to a 3.42 axle from a 2000 Camaro SS. Neither my city or highway mileage changed at all. My car gets 15-16 around town and 27-28 on the highway.
The performance increase was incredible. Felt a bigger difference with the gears than I felt with any other mod.
Old May 25, 2008 | 09:06 PM
Cadillac's Avatar
Re: 2.73's stock?
That's not my experience. I am exclusive, in-town driving and my economy went down. I've had my foot into it a bit more though. It takes off now (well, better than it did before).
Read this: https://www.thirdgen.org/forums/tran...-opinions.html
Nine bolts can be found in a lot of cars but the best ones are supposed to be from the '89's: GTA, TA, some Z28's, IROC's (I think). RPO codes are the best way to tell. Ten bolt cars have the 3.23, 3.42's and 3.73's I think. Some none bolts apparently had a 3.45 too. There are a bunch out there. Avoid the Gov Lock rears. Diff expert to chime in here...
I wish I could say the same for the first part but totally agree with the second.
Old May 25, 2008 | 10:02 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: 2.73's stock?
I let a 3.27 nine-bolt from an 89 formy w/ rear disks sit in my basement for over a year before I sold it for $150.
Wish I had it back.
I'm putting a 350 in now and bought a set of 3.23 gears out of a 4th gen to swap in my old 10 bolt rear.
Can't wait to get rid of my 2.73, but I still want some highway-friendly gears. I think 3.23 is best all-around.
Old May 26, 2008 | 01:45 AM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Re: 2.73's stock?
I went from 2.73 to 3.23 and didn't notice a big change in mpg on the street or highway,but I did see a nice change in acceleration,so I would have to agree with gcgarner,3.23s are the best all around.
Old May 26, 2008 | 03:53 AM
Jix01's Avatar
Engine: 305 5.0 TBI
Re: 2.73's stock?
alright so whats the axle code for 3.23s?
Old May 27, 2008 | 07:37 AM
gcgarner's Avatar
Re: 2.73's stock?
Did you put the gears in yourself or have a professional do it?
My gears aren't going in until my new motor is in (about 2 weeks). I was wondering what the cost of swapping from 2.73 to 3.23 is going to be. Is it anything more than labor & a rebuild kit?
Old May 27, 2008 | 02:12 PM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
Re: 2.73's stock?
i had 3.73s in my 92 and still got 21-22 on the highway, 3.42s would prob be well rounded for everything
and if you have an open diff your going to want to upgrade to a LSD like auburn or detroit true trac
Old May 27, 2008 | 02:27 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
Re: 2.73's stock?
i have a 2.93 posi. i dont know my fuel mileage. i thinks its gallons per mile not miles per gallon. i dont have a problem burning them off but i guess that 450hp is a part of it. hope to have 3.73 soon.
Old May 27, 2008 | 09:26 PM
Cadillac's Avatar
Re: 2.73's stock?
Sounds perfect for a 450HP car.
My ideal ratio for today's mileage concerns and balanced with performance would be the 3.08 posi (carrier II?) and now the 2.93. Seems a good gear. In the carrier III's, the 3.23 and 3.27.
Old May 28, 2008 | 12:50 AM
92RS702's Avatar
Car: 92RS
Re: 2.73's stock?
Actually I swapped the entire diff.My old one was really rusty and had a crack on the pan har mount so it was better to swap the whole thing.
Old May 28, 2008 | 05:17 AM
Jix01's Avatar
Engine: 305 5.0 TBI
Re: 2.73's stock?
so still wondering what i could get 3.23's out of?lol
Old May 28, 2008 | 11:51 PM
92RS702's Avatar
Car: 92RS
Re: 2.73's stock?
Are you looking to get it from the junkyard or buying brand new?
Old May 29, 2008 | 12:39 AM
Cadillac's Avatar
Re: 2.73's stock?
Read the thread OR... consult the site:
Third Gen Tech Data Site for '92 FB.
Old May 29, 2008 | 01:05 AM
Jix01's Avatar
Engine: 305 5.0 TBI
Re: 2.73's stock?
Junk yard hopefully
Old May 30, 2008 | 03:09 PM
92RS702's Avatar
Car: 92RS
Re: 2.73's stock?
Any 3rd gen that is 90 and up will work,just make sure you check that the lsd still works before you take it apart.Have you thought about swapping in a 4th gen rear,you can get them with better brakes and less miles than a 3rd gen diff,and it will bolt in just fine.
Old Jun 1, 2008 | 10:44 AM
Car: ws6
Engine: ls1
Transmission: m6
Re: 2.73's stock?
Alot of people on here say 2.73 to 3.23 is not worth it. Ive always been told 3.45s are the way to go.
Old Jun 1, 2008 | 11:15 AM
Firebat's Avatar
Re: 2.73's stock?
In an automatic, most 3rdgen owners will tell you to get 3.23's or 3.42's. Most 4thgen owners will say 3.42s or 3.73s.
Old Jun 1, 2008 | 04:23 PM
Air_Adam's Avatar
Re: 2.73's stock?
Actually most 4thgen owners will say to START with a 3.73... and most start off with a 4.10 - at least, thats what the 6-spd guys do.
Old Jun 2, 2008 | 04:38 PM
92RS702's Avatar
Car: 92RS
Re: 2.73's stock?
For a 3rd gen with an automatic 3.73s,and 4.10s are way to low.For nice performance and decent gas mileage go with 3.23s or even 3.42s,they are very close to one an other,you won't regret it.
Old Jun 2, 2008 | 07:07 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Re: 2.73's stock?
My gf's 2000 T/A auto had 2.73s, yes rare but it did, also has a steel ds. We just swaped to a 3.42 rear. Her mpg went from 27 highway to 22-23. City mpg stayed the same.
I would go with 3.23s if your concerned with mpg. You WILL notice a big difference in off the line acceleration. When i went from 3.23 to 3.73 i also noticed a big increase of acceleration.
2.73 to 3.23 is a perfect swap for a street car. Automatics of course.
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Regal105
Aug 23, 2015 03:45 PM
knight72
Aug 10, 2015 09:32 PM
