whts good posi?
Old May 24, 2008 | 09:28 AM
xfactor200289's Avatar
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Axle/Gears: 9inch 3.50 gear
whts good posi?
Wht do you guys rec. for a good posi for built 10 bolt, the car makes over 450hp to the rear wheels it has a aburn in it now it is junk. any input would be helpful. thks
Old May 24, 2008 | 09:42 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: whts good posi?
Well if you are looking for a good Posi, check out the Positraction one.
Old May 24, 2008 | 10:53 AM
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Re: whts good posi?
is that the name of a company?
Old May 24, 2008 | 06:25 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: whts good posi?
I've heard very good things about the Zexel-Torsen diff from the '98-02 LS1 F-bodies. They seem to work really well, they are quite strong (for a 7.5" diff), and since they are all mechanical internally there are no clutches to wear out. Thats the route I would go for a 7.5" rear end.
Honestly though, with anything making even 450hp at the crank, nevermind at the wheels, you are going to be changing broken rear ends every time you fill up the tank.
Old May 25, 2008 | 02:48 AM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
Re: whts good posi?
is this guy freakin serious???? i dont think soooooo!
Old May 25, 2008 | 07:03 AM
DJP87Z28's Avatar
Re: whts good posi?
He is so serious he wants a POSI for that beast. He should get Chevrolets best the" Gov-lock Posi".
Old May 25, 2008 | 08:15 AM
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Re: whts good posi?
ya im serious just trying to see if their is a better posi than the aburn that i have. the street car runs 11.29@124 with 1.73 on DR wtih a slipping posi. the gov-lock is a POS.
Old May 25, 2008 | 02:59 PM
Air_Adam's Avatar
Re: whts good posi?
If the posi you have now is working properly, you won't really gain anything by changing it. If you do change it, I still stand by my suggestion. Detroit Locker would also be a good choice, but I honestly can't remember if they make one for the 7.5" or the 9-bolt.
Old May 25, 2008 | 03:13 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: whts good posi?
detroit true track- a lot of people seem to prefer that unit...at least all the people i've talked to.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
mcgarnicle
Aug 12, 2015 04:58 PM
