700R4 shiftpoint question?
Old Jun 5, 2008 | 04:22 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Can a bad speedo gear drive, affect shiftpoints on an '83 700R4?
Previous owner claims that tranny was rebuilt about 2K miles ago with a "Corvette servo". The speedometer needle flutters alot and even at WOT the trans shifts at only about 3500 RPM or so - no higher. I was trying to see if there is a connection between the speedo and low shift points.
Old Jun 5, 2008 | 08:51 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: 700R4 shiftpoint question?
The computer gets vehicle speed from speedo and controls when to lock and unlock the converter. Other than that, no.
Check TV cable adj for early shifts.
Old Jun 5, 2008 | 09:08 PM
chazman's Avatar
Axle/Gears: BW 3.45
Yeah, I adjusted the TV cable. No difference.
And that 'Corvette servo' (if that's what it really is), is just plain annoying. At WOT it chirps the tires hard at it's 3500 1-2 shift point, even breaking the rear loose and causing it to fishtail. And I don't think it downshifts as agressively and effectively as it should either. Hey, I 've got an LU5 and 2.93 gear, I need all the help I can get. And this trans is just not doing it's share.
I'm thinking of just going to a tranny shop and having them replace the servo with a stock one and having them reset the governor.
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
