Speedometer cable to VSS conversion
Old Jun 15, 2008 | 09:04 PM
EROC88's Avatar
Car: 88 IROC-Z
Engine: 355 T.P.I.
Transmission: t56
Axle/Gears: gm 10 bolt, 3.90 gears
i have a few questions about this conversion. i'm putting a t56 in my 88 Iroc that was originally an automatic and am concerned about the speedo cable.
first off- without a speedometer reading the car is not supposed to run right and will set a check engine light when the cable is disconnected. is the only thing needed to make it run right a signal at the speedo?
i don't quite understand how using the SGI 5 box that eliminates the cable that runs the speedo allows it to get an accurate reading for the computer. does the computer just need to see the speedometer moving for it to work right? and how does this SGI 5 get the speedometer to move anyways?
is there any way at all to install the speedo gears from the automatic onto the t56 and have it be mechanical? is there any way at all to just make the t56 mechanical and just use the orginal cable?
Old Jun 16, 2008 | 01:15 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: Speedometer cable to VSS conversion
Read my reply to this same question about a mechanical speedo drive at the thread I've linked to below. I think my post is the fourth one from the top.
There seems to be so much interest in this I just may offer to do the mechanical conversion for members here.
https://www.thirdgen.org/forums/tran...swap-done.html
Old Jun 16, 2008 | 11:33 AM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
http://www.southweststreetworks.com/
If you send them your tailhousing they can machine it to accept a speedometer cable.
Old Jun 16, 2008 | 02:45 PM
89IROKCONVERT's Avatar
i just did the t56 conversion on mine what did you do for a transmission crossmember? also has anyone gone with the aftermarket electric speedo ? im trying to find a speedo that will fit in my cluster and take the glass and trim off to install it in the factory hole . also this tail housing conversion it looks like they just put a new hole in the trans why cant i just do this myself ? btw i dont think it should change the way the car runs because we dont have the VSS in the gen three just the TCLS am i thinking correctly ?
Old Jun 16, 2008 | 07:22 PM
vbMike's Avatar
I used a crossmember and torque arm from spohn. It's okay but the crossmember is rather low and the torque arm is noise. I rather have something different. Thirdgens do have a VSS and the idle will be crappy without it hooked up.
Old Jun 16, 2008 | 08:03 PM
ok cool i fabricated a whole new crossmember i would have felt stupid if there was a stock one out there that would work.
Old Jun 16, 2008 | 11:04 PM
EROC88's Avatar
Car: 88 IROC-Z
Engine: 355 T.P.I.
Transmission: t56
i got one from BMR fabrication. it includes a mount for the torque are so that it is mounted on the crossmember instead of the tailshaft.
Old Jun 16, 2008 | 11:10 PM
EROC88's Avatar
Car: 88 IROC-Z
Engine: 355 T.P.I.
Transmission: t56
is there any kind of box i can buy that you somehow plug the mechanical wire into and it converts it into the vss signal? does something like that exist? cuz that would be GREAT!
Old Jun 17, 2008 | 02:44 AM
alloy's Avatar
Car: 87 IROC-Z28
$550 for that and you supply the housing??? I can't even think of anything to say, I'm completely speechless.
Old Jun 17, 2008 | 06:10 PM
for 310 + s+h you can get a box from abbot its called a cable x box but i just spent the money for a 150 stock speedo so im going to see if a local machine shop will drill the hole in the new location for me (because i only have one shot and it needs to be perfect) then i think i can fabricate all of the other parts myself with a simple lathe
Old Jun 17, 2008 | 07:00 PM
wow alloy your talking about the tail shaft i cant understand people paying 400$ for a trans crossmember
Old Jun 18, 2008 | 07:48 PM
andresinibus's Avatar
Car: 85 Z28 W/T-Tops
Engine: 383 crate engine edel carb n headrs
Transmission: ex700R4/NOW T5
Axle/Gears: 3.08 std
about a carburated engine will it get affected without the speedometer connected and just to be sure without the cable to box or paying the money to get the tranny fix up there is no way to make the speedometer work if you put a tranny with a vss
Old Jun 20, 2008 | 12:10 AM
any body?
Old Jun 22, 2008 | 06:58 AM
vbMike's Avatar
Well I talked to the guy and was able to get mine tailhousing done for $300. I tried the abbott cable x box first but wasn't happy with it so I went this route instead. There used to be a pdf document on here that gave instruction and measurements so that you could take it to a machine shop and have the work done. The hole has to be exact or the gears won't line up with the output shaft. Also the sleave that goes inside will have to be a good tite fit or the tailhousing will leak tranny fluid.
Old Jun 22, 2008 | 02:19 PM
alloy's Avatar
Car: 87 IROC-Z28
What specifically was the problem with the Cable-X box?
I'm not real fan of something like that, that's why I went mechanical. Cables have been around for many years now and my T5 cable works perfectly. (That's after I replaced my stock 2 pc. cable with a single pc. new one). Speedo is steady and doesn't bounce at all.
I just finished my 3rd T56 cable drive conversion yesterday. Did two for others first, then finally got time to do mine. Got one or two more to do this next week depending on when UPS gets around to delivering them.
Old Jun 22, 2008 | 04:22 PM
vbMike's Avatar
The needle was a little bouncy because the motor that drives the cable just isn't as smooth as a directly driven cable would be. Not a big deal and it does work just fine. I orignally went with the cable x because I didn't want to remove the tail housing from the transmission. I was worried I wouldn't be able to get it back together, etc. I had the cable x box in stalled instead and it worked fine. I can't remember if I tried my cruse control but I think I did and I believe it worked fine. Anyway my tranny ended up having bad syncros and needed to be rebuilt so since I was going to tear it apart anyway I figued I get the tailhousing machined to work with my speedometer cable.
Old Jun 29, 2008 | 01:30 PM
alloy's Avatar
Car: 87 IROC-Z28
Here is a pic of my conversion.
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
2012sergen11
Oct 13, 2015 07:38 PM
RS Reaper
Sep 27, 2015 07:04 PM
