700r4 wont shift into 2nd or 4th
Old 06-16-2008, 01:08 PM
Daniel12345's Avatar
I have just finished putting my 85 700r4 back into my car after a fresh rebuild and i dont have 2nd or 4th gear but i do have reverse and all the othe gears. could this be the servo?
I replaced all the seals on the servo before reinstalling it and would just like someone elses opinion before i go tearing into it. Any help is appreciated .
Old 06-16-2008, 03:19 PM
Pro Built Automatics's Avatar
Re: 700r4 wont shift into 2nd or 4th
After the rebuild did it ever have 2nd & 4th gears?
Old 06-16-2008, 07:36 PM
No,the first time i test drove it after rebuild it just completly skips 2nd so you have to rev it to get it to shift to 3rd then no 4th.
Old 06-16-2008, 08:30 PM
There is a good chance that the band is not on the anchor pin. The pan would have to be dropped to see if this is the case. This can possibly could be fixed from the bottom.
Old 06-19-2008, 02:47 PM
Ok i droped the pan and it looks as if the pin is seated correctly. The pin looks to be in its bore all the way and i cant really see it on the band but i pushed it with my fingers and it feels like its on it. Any other ideas on what this problem could be.
Vojtush31
10-11-2015 01:07 PM
91L98Z28
Southern California Area
09-19-2015 09:35 AM
xXIROC ZXx
Wheels and Tires
09-15-2015 11:18 PM
TheTraut88
09-07-2015 05:22 PM
rudolphschenker
09-04-2015 02:41 AM
Quick Reply: 700r4 wont shift into 2nd or 4th
