Looking to bump up my rear end with some gears!
Old Jun 24, 2008 | 11:24 PM
my9225thanni.'s Avatar
Car: 92 25th anni camaro RS
Engine: V8 305 TBI
Hey everyone I have a 9-bolt rear from an I-roc and i want to bump up the gear ratio just don't know where to start looking for it. Its stock posi unit i believe 3.27 are in it i would like to go higher. If anyone can let me know where to buy the gears or have any other suggestions let me know. I'm located in north NJ.
Enrico
Old Jun 25, 2008 | 12:00 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Looking to bump up my rear end with some gears!
Most common step up is 3.45 and 3.70 but the 3.70 gears were not in a production car. Gears and other parts for the 9 bolt are hard to find. The diff comes from Australia where there are lots of parts for them.
The 9 bolt was only available for 3 years in the f-body and only in certain models. Since there's isn't a high demand for parts other than bearings and seals, nobody carries anything.
Many times it's just easier to swap in a 10 bolt for better gears, posi etc.
Old Jun 25, 2008 | 01:32 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
I wouldn't be worrying about gears just yet. 3.27 is just fine with what you have for now. just be thankful you don't have that awesome 2.73 open rear anymore.
I'd go with a cam, torque converter, and full exhaust before i'd even consider worrying about a gear swap. much better bang for the buck. get rid of the weak links first.
Old Jun 25, 2008 | 07:39 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Sites for 9 bolt gears:
Jawsgear
Justdifferentials
Accuautoparts
I haven't used any of these sites. If you have 3.27 now, the 3.70 ratio will be a nice step up.
Old Jun 25, 2008 | 08:12 AM
AlkyIROC's Avatar
Car: 87 IROC L98
I ran into the 11's with 3.27 gears.
Old Jun 25, 2008 | 05:48 PM
Engine: V8 305 TBI
I started last month i put in a new cam timing gears new intake bigger throttle body with spacer new lifters 1.6 roller rockers new pushrods full exhaust with cut out so i have a good amout of stuff so thats y i want to pump the rear up.
Old Jun 25, 2008 | 05:53 PM
Engine: V8 305 TBI
Jawsgear
Justdifferentials
Accuautoparts
Thanks for the sites unfortunally i am kinda in the blue when it comes to buying the gears which ones from which site would you recommend also wat else would i need to purchase to put them in correctly. Thanks for the help. Enrico
Old Jun 29, 2008 | 08:07 AM
Pat Hall's Avatar
You'll need a master installation kit(bearings, seals, shims, etc.) to go with the new gears. Justdifferentials sells the installation kits too IIRC. If you've never done a gear install, you really need to find someone who's experienced to help you, or pay a shop to do it. It requires some specialty tools and is definitely not a job for a novice.
Old Jun 29, 2008 | 10:08 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
If you are "kinda in the blue" forget about trying to bump up your rear until you do a little more research. Not the the DIY project that can be answered in one or two sentences. Just my opinion.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
