Tranny swap
Old Sep 11, 2000 | 10:32 PM
JC88Camaro's Avatar
Tranny swap
I have a 88 camaro with a 83 305/700r4. The engine has less than 1000 miles on it while the 700R4 has over 80000 miles. I am having trouble with the engine heating up only when I get on the gas or climbing any hills big or small. I have noticed the tranny slipping badly in first and into second. A friend of mind told me the tranny was causing the car to heat up? I found a turbo 350 for 75$ from another friend of mind. It only has 35000 miles on it. I would like to swap if I knew for sure if it was the problem. Is it hard to make the change from the 700R4? Thanks
Old Sep 12, 2000 | 08:10 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
I haven't done a 700 to 350 swap. But what I have heard you will need, a new driveshaft, or possably a long tailshaft TH350, will work with your current DS. Besides that the 350 will bolt right up to the block no ?. Shifter cable I don't know if it will work or not.
Later
John
82 Firebird,355,Cam 224/234, .466/.488,TH350 Tranny,650 HolleyDP,Hooker Headers(I.E. POS) Manual steering,Lakewood LCA's,15X9 Centerline Warriors 275 50R15's BFG Drag Radials
Best 8th et 8.81@80mph.
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
