how much hp and tq will t5 and rearend hold?
Old Jul 11, 2008 | 10:12 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
my new 383 was just finished being built. it should have around 400 hp and 450 lb/ft of tq. i have heard that these transmissions will not stand up against that much hp. will just one gear go at a time or all at once? what about the rearends? what should be done to strengthen the rear?
Old Jul 12, 2008 | 12:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: how much hp and tq will t5 and rearend hold?
the t5 is rated for under 300ft/lbs. 3rd gear is where they usually break, though other gears may go out before that. It will work and live a decent life if you use the clutch to shift, no powershifting, dont use slicks and dont clutch dump the car.
as for the rear, its hit or miss. some people break them with a stock motor and other have put down pretty good numbers with one. If its an open rear it will last the longest, less traction/longer life. there is really no way to strengthen it, the ring and pinion are too small and they are are the weak point. You can use aftermarket axles, posi units, gears, ect to try and beef it up a bit, but the ring and pinion will still be the weak point. Once again if you drive it conservatively it will be fine, if you beat on it, it will eventually blow up.
Save your pennies for a 12bolt or 9" rear.
Old Jul 12, 2008 | 01:06 PM
mesterz2889's Avatar
i agree with 86 but it also depends what t5 you have the world class t5 (89-92) can hold a little more power
Old Jul 12, 2008 | 06:28 PM
brodysZ28's Avatar
Engine: 383
i have the stock 83 transmission... is it an indication that its ready to go if it is already whining? how much are those rears? are you talking ford 9 inch, or are they direct bolt in?
Old Jul 12, 2008 | 07:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you can get direct bolt in 12bolts and ford9" rears from moser engineering, or through Spohn performance and other vendors. Strange engineering also make a 12bolt and a dana60.
They start at 1900 and go upwards of 2750 depending on setup, not cheap by anymeans but they hold the power.
if the trans is wining, its on its way out.
Old Jul 13, 2008 | 01:36 PM
brodysZ28's Avatar
Engine: 383
hmm, that sucks, i guess i will have to take it easy for a while, even though thats way easier said than done. are the lower priced ones limited slip. how do you like that tko 600? that is probably what i would go with if i had to replace my tranny.
Old Jul 13, 2008 | 05:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the cheapest one would be with a spool, not good for the street, the posi ones go for more.
So far i really like the TKO, its a very positive shifting trans, no guessing if your in gear or not, and its quite stout. Again they are not cheap either.
Old Jul 13, 2008 | 07:16 PM
brodysZ28's Avatar
Engine: 383
is a spool locked all the time? how much more is posi?
RedLeader289
May 28, 2019 01:47 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
mattcanty
Oct 12, 2015 11:08 AM
Briandrex
Oct 5, 2015 06:20 AM
racereese
Oct 3, 2015 03:46 PM
