shifts strange
Old Jul 13, 2008 | 01:44 PM
kosbo77's Avatar
Car: 1990 trans am gta
Engine: 5.7 ltr 350 stock
shifts strange
I have a 1990 GTA with a rebuilt 700. The transmission was rebuilt about 4 months ago before I bought the car. I seen the receipt. Now I am not real familiar with these higher power cars seeing as I have only owned a v6 firebird and a v6 camaro, but here's my problem. When I drive around town (35-45 mph), the car won't shift until around 4000 rpm. It seems to me that it should shift sooner than that because I feel I'm screaming down the streets and only going 40 mph. On top of that, when I let off the gas, my tach will go back down to about 1200 rpm until I step on it again. Then there's what I call a catch up time when the tach will climb back to around 2500 rpm before I feel the car accelerate more. I don't know if this is normal but to me it doesn't seem so. Do I need to get someone to look at it? I'm pretty sure it's still under warranty. Thanks.
Old Jul 22, 2008 | 02:10 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: shifts strange
TV (kick-down) cable adjustment I think.
Old Jul 22, 2008 | 02:27 PM
kosbo77's Avatar
Re: shifts strange
Thanks for the reply doc. I've tried messing with the cable and I'm pretty sure it's where it needs to be. I've followed all the instructions on here and am pretty confident. I have a replacement governor on the way since it's quick and cheap. Worth a try I guess.
Old Jul 25, 2008 | 10:48 PM
Moonlight's Avatar
Car: 1991 Z28
Transmission: 4l60e
Re: shifts strange
it could quite possibly be a vaccume leak, as im having the same problem you are where it shifts at 4g, if u can hear a like a hum or somthing other then straight revs, its most likley a vaccume leak or u need a vaccume module (which is a very cheap fix.)
Old Jul 26, 2008 | 12:31 AM
Pro Built Automatics's Avatar
Re: shifts strange
Do you have engine braking in manual 1st or 2nd gear?
Old Jul 26, 2008 | 08:29 AM
kosbo77's Avatar
Re: shifts strange
Moonlight,
I bet you're right. When it revs, I can hear a high pitched humming noise. I'll check it out. Thanks very much.
Old Jul 26, 2008 | 10:43 AM
kosbo77's Avatar
Re: shifts strange
Ok changed the governor. Put everything back. Lost some fluid. Replaced fluid. Took for a test drive and started out fine. Then started slipping. Got home and checked dipstick. Hard to tell but looks like I may have overfilled some. Is slipping tranny a common occurrance if filled too much? I am an idiot.
Old Aug 8, 2008 | 01:06 PM
87GTAj's Avatar
Car: 87 Trans Am GTA
Engine: 5.7L TPI
Re: shifts strange
I've got a similar problem - when I'm cruising around town, and I'm driving at say 25-30 MPH, if I press the gas more, the RPMs climb maybe 300-400 and then I finally feel the car "catch" and accelerate. I haven't looked at the TV cable yet, but could this or a vacuum leak be the problem and can someone explain why? Thanks.
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
