Aluminum Driveshaft
Aluminum Driveshaft
Why does everyone mod out there cars completely but always seem to over look the Driveshaft? You could be ALOT lighter with an aluminum one...But does anyone else know anything other than being lighter that the aluminum drive shaft does?
They are better balanced (eliminating/reducing high speed vibration). The aluminum driveshaft lets you also rev up quicker but also with less mass pushing agains the engine it also slows faster.
'84 Trans Am
Crate 350 - 4 bolt main, Holley 600 w/vac. secondaries now open element
T-5 - Stock with Zoom clutch and PP
'84 Trans Am
Car: Take
Engine: Your
Transmission: Pick
New ones from GM are like 300-400 bucks. Aftermarket or used are the way to go.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'97 Bonneville SSE
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Would the same drive shaft fit an automatic and manual car, 700R4 & T-5??
'86 TA, T-tops, T-5, 3.73, 4 wheel disks 350, compucam 2040, performer intake,SLP Headers, 3" race magnum muffler, 1.6 Comp rockers, Ripper shifter, perf. friction pads, Hypertech ignition, Earls brake hoses, Hotchkis springs, Tokico Illumina 5 adjustable shocks and struts, Lakewood panhard and trailing arms
14.73 @ 95... traction still a problem
Car: Take
Engine: Your
Transmission: Pick
Yes. Compatability is why GM makes so much money. They don't need seperate parts for different setups!
South East Thirdgen
Savannah, GA
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'97 Bonneville SSE
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Hey, Guys,
I sell used GM alum shafts, 88-92 Camaro, TA, and Firebird (p/n 10085375), regularly on this site. $155 shipped, money order, certified check or PayPal. If you have questions or concerns, please e-mail me.
JamesC
JamesC
I bought one from james. Good pieces. That is for sure the way to go. I just replaced the u joints and put it in the car.
89 Formula 350
Rebuilt suspension, Aluminum Driveshaft, 3.70 gears
T56 siting in my garage till next months swap.
Best 1/4 mile - 15.08 bone stock.
89 Formula 350
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The 1LE d/s is about 2 3/4" in diameter.
The LS1 d/s is about 3" in diameter and both will work. The LS1 is a bit cheaper. Dal can get you a new GM one for about $330 for the 1LE.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
-Justin-
