rear seals
Old Mar 9, 2009 | 08:13 AM
S91Formula5.7's Avatar
Car: 1991 Pontiac Firebird Formula
Transmission: 700 R4
rear seals
i was wondering how hard it is to change the rear axle and pinion seals. i was thinking about doing it myself, but i first wanted to know how difficult it is. My mechanic told me that the seals were leaking oil into the brakes, and that it needs to be fixed pronto. He told me thatd it would probably be around 4oo to fix it if he did it, so i wanna save some dough and do it myself. Any recomendations?
Old Mar 9, 2009 | 08:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear seals
Welcome to TGO. A search will nearly always provide the info you're looking for. Check the following link for the axle seals:
https://www.thirdgen.org/forums/tran...ing-axles.html
BTW, if the seals are leaking, the bearings are probably shot--and perhaps the axles as well. If so, you might consider an off-set bearing or axle saver bearing.
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
