Cooling a T-5? Adding a Dipstick?
Old Jul 21, 2008 | 02:05 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
I was wondering how you could hook up a tranny cooler on a t-5? Would it be worth the effort if it's possible? Was under there changing the clutch out and have been thinking about it since. How about the addition of a dipstick tube? Mine has what looks like one that is capped off from the factory, maybe a foot long.
Old Jul 21, 2008 | 03:03 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Cooling a T-5? Adding a Dipstick?
You can run a trans cooler on a T5 but you will need to add a pump and some other mods. I don't think it is worth it, since you aren't going to be driving at max rpm for hours at a time.
Old Jul 21, 2008 | 05:43 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
You've never seen me drive What kind of pump would one use?
Old Jul 21, 2008 | 06:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It doesn't matter how you drive, you won't need it.
Old Jul 21, 2008 | 06:16 PM
Zepher's Avatar
Found this on another forum,
Prototype Testing Results:
Car warmed and driven for 25 minutes prior to start of test w/ cooling system off.
12 mile stretch of road used for test runs, repeated boosting and acceleration/deceleration. 9 runs per pass:
Temp prior to testing start - 117.8F
Test Run 1 w/ cooling system on: Peak Temp - 120.6F
Test Run 2 w/cooling system off: Peak Temp - 134.4F
Cool down driving w/cooling system on following run 2: 118.6 after 7 minutes (120.9 after 1 minute)
Doesn't seem worth it for the small gains in cooling.
Here are the parts used:
Tilton 2gph Oil/Differential Cooler Pump
Earls 10 pass oil cooler
-8 SuperStock Line
4 -8 hose ends
2 adapter fittings to attach to the transmission
2 angle fittings for in and out of the pump (-8 optional)
Old Jul 21, 2008 | 06:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Hot oil inside a manual transmission isn't going to hurt performance unless it's in extreme use such as a stock car running around a track for 2 hours or a heavy truck pulling a heavy load. Oil temperatures that get above 230* is when you need to start looking at a cooler.
Driving down the highway for 2 hours is not extreme use.
Old Jul 21, 2008 | 06:59 PM
DM91RS's Avatar
Car: 91 RS
It would be with your engine running at heavy throttle.....
Old Jul 21, 2008 | 07:35 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Thanks for the info zepher. I was just looking to maximize longevity. Looks like temp isn't much of a concern after all. Guess you learn something new everyday.
Old Jul 21, 2008 | 08:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Even running in the Silver State Challenge won't be enough.
Old Jul 21, 2008 | 10:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The gearbox neither knows nor cares how heavy your throttle is.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
gord327
Oct 3, 2015 01:25 PM
