NEED HELP!!! NO DOWNSHIFT???
Old Oct 15, 2000 | 02:29 PM
StockBastard's Avatar
I have a 700r4 and I put a transgo shift kit in about a month ago. Ever since then my transmission will not downshift once it upshifts into any gear. I can manually do it, but I can be going 15 mpr and if it's allready in 2nd, it isn't going back into 1st. What did I do and how can I fix it???
"Why StockBastard?" you might ask. Well...
84 Berlinetta body w/custom paint.
92 front/rear bumper and ground affects.
89 IROC 350tpi engine w/lots of mods.
87 3.73 possi rear w/disk brakes.
86 interior w/IROC dash.
And finally, stock Vet rims from the early 70s.(same ones used on the 69ss)
ALL IN ONE CAR!!!
Old Oct 15, 2000 | 03:34 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Since there are many different brands and levels of shift kits, please list everything that you installed during the "upgrade".
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Old Oct 16, 2000 | 06:28 PM
87 Firebird's Avatar
You may have a problem with your Throttle Valve cable. Adjust this near the throttle body. There's details of the adjustment all over this board, just search for it. It could be causing all your problems because if it's not adjusted correctly, then it would alter your kickdown in the tranny. Add a shift kit, which modifies kickdown even more, and voila! No kickdown. Just my thoughts. Best of luck.
Prodigious
Nov 7, 2020 09:23 AM
tyeo098
Nov 30, 2015 06:27 PM
someone972
Aug 30, 2015 12:52 AM
JeffP
Jan 4, 2001 11:46 PM
