Identifying a 700
Old Oct 17, 2000 | 08:13 PM
drt-rcr's Avatar
Identifying a 700
I was given a 700R4 by my brother. I don't know what he got it from. I'd like to identify it to make sure it's one I can use and how it all needs to hook up.
The rectangular pan tells me it's a 700.
It has a 4 pin square connector towards the top left rear pointing straight up.
There is a small yellow tube coming out of the top of the case just behind the front pump area. I'm guessing it's a vent.
The cooler lines are higher on the case and a little back from where they are on a Th350.
There is a piston/cylinder on the right side of the cse just behind the fill tube hole.
I know there were #'s on the TH350's that could tell you what was originally installed in. Is there something similar on the 700's?
There is a large hole where the pickup for the speedometer. Are there different pickups for this trans and should it be a cable or electronic?
Lastly, how much torque are these trans rated for?
Thanks for any help you can offer,
Matt Brown
Dirt Late Model racer and Third gen lover.
91 V-6 bird with 406 in process.
[This message has been edited by drt-rcr (edited October 18, 2000).]
86IROC112
Nov 27, 2015 09:54 AM
armybyrd
Oct 24, 2015 06:59 AM
Linson
Sep 21, 2015 01:08 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
