How hard is it to replace a pinion bearing?
Old Oct 17, 2000 | 04:39 PM
Justy's Avatar
I've been looking for a limited slip rear for my '84 Z28 and I've only found one around here. The wrecker dude told me it needs a new pinion bearing. Is this a difficult job? It's a '91 with a 3.42 ratio. I was hoping to just change fluid and swap it (the whole axle) in because I don't want to wreck anything. Thanks
Old Oct 17, 2000 | 08:55 PM
ede's Avatar
ede
not a hard job, but requires some tools most people don't have. you'd need a inch pound torque wrench, with a dial. depth mike, or pinion setting gauge, dial indiactor, and a press and bearing seperator. it should only be a few hours labor for a garage to do it, you might want to ask around. if you want to do it your self post again or e mail me and i'll run through it for you a little more.
-=ICON MOTORSPORTS=-
Old Oct 18, 2000 | 01:24 PM
Justy's Avatar
Thanks for the info. I don't have those tools so I'll get some quotes and decide whether it's worth it... if not I'll probably just hold out for some 3.73s!
Justy '84Z
red90IROCls1
Aug 25, 2015 06:56 AM
db057
Aug 22, 2015 08:17 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
rsrmoore
Aug 7, 2015 08:44 PM
