rear gear
Old Jul 29, 2008 | 05:35 PM
89bird350's Avatar
rear gear
i hve a 1991 chevy camaro z28 drum brake rearend i took the 2.73 rear gear out and went to swap it with the 3.42 out of a 83 v6 5spd firebird it dont seem to fit i thought id swap right in help
oh yeah i used my carrier and axels in my housing
Old Jul 29, 2008 | 09:04 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear gear
Welcome to TGO. There's a difference between series two and series three carriers. A search will provide more info.
JamesC
Old Jul 29, 2008 | 09:35 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: rear gear
Your 2.73 carrier is a Series 2. Works fine up to 3.08. Any ratio with a higher number than that requires a Series 3 carrier.
You have 4 choices:
1) Swap the carrier AND the ring & pinion from the V6 car to yours (but I'm guessing the V6 car's carrier is an open diff, right?) Free, but you're left with a peg-leg
2) Buy a new Series 3 posi carrier to work with the 3.42 gears. This can be expensive if you buy a new carrier. Used ones can be picked up on Ebay. Just stay away from anything that says Eaton G80 or GovLok.
3) Buy a "thick" ring & pinion (I got mine from Randy's Ring & Pinion for $169) to fit your current Series 2 carrier. Obviously, this was my choice.
4) Buy a ring spacer to put on the back of your ring gear to make it thicker. I have heard serious horror stories about this and don't recommend it. One story even involved a death.
Welcome to TGO. Wealth of information on here. Lots of BS too lol. The "search" feature can be your best friend!
Old Jul 30, 2008 | 06:07 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: rear gear
I think I will do a gear change, and the parts don;t fit. I wonder why???
Old Jul 30, 2008 | 07:29 AM
gcgarner's Avatar
Re: rear gear
Uncalled for.
Old Jul 31, 2008 | 05:57 PM
89bird350's Avatar
Re: rear gear
i ended up buying the spacer just for now dont have the money to buy new carrier right now and as far as the rude comment i have the experience but it on ford rearends i never dealt with a chevy rearend
Old Aug 1, 2008 | 08:02 AM
gcgarner's Avatar
Re: rear gear
Be careful if you put down the power.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
