Why cant i hit red line?
Old Jul 30, 2008 | 08:36 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Ok guys before i had my shift kit and stuff installed it would hit the yellow line what ever. But now 1st to 2nd it shifts between 3k and 3500 then all the shifts can be made at red line i am very confuessed. Please help i want 1st to 2nd at red line!
thanks
kevin
Old Jul 30, 2008 | 08:41 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: Why cant i hit red line?
manual shift, then you will redline. Your building too much vacum too fast causing your transmission to shift. When you manual shift your forcing your tranny to stay in that gear which will make you redline and with the corvette servo it wont let the tranny shift before redline when manual shifting. just my
Old Jul 30, 2008 | 08:51 PM
It wont hurt nothing getting up in high rpms will it when i manual shift?
thanks
kevin
Old Jul 30, 2008 | 09:20 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
no it shouldnt. its still automaticaly shifting...your just changing the shift point by doing it manualy
Old Jul 30, 2008 | 09:24 PM
Engine: Vortec 357
no it wont, plus it will make the shifts snappier and your tires will sqauck more going into 2nd because of the higher rpms. Just make shure you dont overrev it because you will either break the motor or snap something in your tranny due to the over excess of rpms.
Old Jul 30, 2008 | 09:32 PM
So then i will get a louder bark b/c right now its a quick bark but not nothing special.
kevin
Old Jul 30, 2008 | 10:40 PM
Engine: Vortec 357
kevin
yes it will be louder and longer. Ive even left black marks in a friends driveway if you shift at just the right rpms. i have noticed that i do get alot of play in the rear when it shifts because it tourqes the car so much so i have to upgrade my sway links and suspension bars in the rear to stiffen it up.
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
z28_AJ
Aug 27, 2015 08:59 PM
