Please Help! I'm Screwed!
Ok, 92 RS 305. I lost 4th gear/overdrive. now for the past two days, it wont shift into third until a good 30,000 rpm. At first we thought it might be a stuck valve. But now this with the third gear i'm thinking it's something else. or the whole transmission. any suggestions? i'm desperate!
92 25th anniversary
edition RS. 305 TBI
Straight stock but a
ram air hood and
flowmaster exhaust
"SUPER SLOW"
92 25th anniversary
edition RS. 305 TBI
ram air hood and
flowmaster exhaust
"SUPER SLOW"
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
jill i hope the 30,000 rpm was a typo
. i don't know much about transmissions but i'd wonder about the governer. you have checked the fluid level? take it to a shop and let the check the fluid preasure and see what they tell you.
-=ICON MOTORSPORTS=-
![](https://www.thirdgen.org/messgboard/smile.gif)
Unfortunately not a typo. it's getting worse too. today i was driving and i got it up to 60 and it still wouldn't shift. have checked the trans fluid and filter. governer is a good idea. i'll have to check that out. thanks
You are misreading the tach. It's times 100 not times 1000 on a two digit tach or times a 1000 not times 10000 on a single digit tach. Not even top dragstars can spin 30,000!!! You were not shifting to 3,000 which isn't to bad...if you were flooring it and it didn't shift to 6,000 that's actually desirible. If it wouldn't shift until that high under normal conditions then you have a problem. For now, attempt to adjust the throttle valve cable (Refer to haynes manual) I'll need more info about type of shifts, timing of shifts, feel of shifts, tranny fluid color, last filter change, operation temp and miles before I can even start poking at it....
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 WS6 Trans Am T-top car
4-bolt main 350, headers, Holley 650, T-5 and 3.23's.
Daily driver and restoration
[This message has been edited by 84FTA (edited October 30, 2000).]
ok you are right i'm sorry. but no it's still not desirable. i like the fact that my car has that high of a shift range, but not when it wont shift driving normally until 70mph. detent cable has already been checked. trans fluid and filter were changed about two months ago. i just hit 100,000 miles on the car unfortunately. temperature is normal. shifts kind of sloppy. hard to explain. It's doing it quite selectively. i thought only when it's cold but it warmed up and proved me wrong. the fact that i already lost fourth gear and then this kind of tells me it's time to say screw it, sell my body, and get a new transmission. if it keeps running like this i'm gonna end up blowing my motor.
Car: 92 RS 25th Aniv. V8
Engine: 350 L05 TBI
Transmission: 700R4 Raptor
Jill does your tranny ever slip? I have the same car and mine started slipping after I put in a new 350, the Tranny guy told me that this is the first sign before the loss of gears, my car has 120,000 miles on it. The tranny guy went on to say that it is time for a rebuild (soft parts). OUTCH!
A quick note, my tranny will be here by this friday, if this ends up to be your story, just keep one thing in mind, alot of improvements have been made to the 700r4 trans since our car was made, ie; more clutch packs, so looking outside of the rebuild may be advantageous.
--G
92 RS 25th Aniv.
350 Goodwrench
--G
92 RS 25th Aniv.
350 Goodwrench
suprisingly it never slips. i had that happen with my taurus and had to get the thing rebuilt so i know what it feels like if it did. hopefully it wont start either. i'm thinking about trying the governer and if that doesn't work, then i dont konw what i'm gonna do
RedLeader289
05-28-2019 01:47 PM
LT1Formula
10-08-2015 08:34 PM
