vss help
Old Aug 2, 2008 | 10:17 PM
1fastcamaro88's Avatar
Car: 1988 camaro sc
Engine: nasty 305 tbi,tba 632 big block
Transmission: built 700r4
vss help
can anyone tell me were the vss is on my 88 sc camaro 305 tbi? i have an idea but not exactly sure,also is hard to change? i put a code scanner to my car and pulled a code 24 vss shorted and 44 o2 sensor is shorted
Old Aug 3, 2008 | 06:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: vss help
Rear of the cluster, IIRC. According to my 85 shop manual, you're to disregard code 24 if the car isn't moving.
JamesC
Old Aug 3, 2008 | 07:08 AM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
Re: vss help
The vss sensor itself is on the tranny. look on the drivers side rear of tranny for a plug. and the vss buffer box is on the pass side under dash a yellow box about 4in square if you look up under the dash just behind the panel it there.
Old Aug 3, 2008 | 07:13 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: vss help
On a '91 it is on the tranny itself. On a '88 that the OP has, it is behind the guage cluster as James has stated.
Old Aug 3, 2008 | 08:31 PM
Car: 1988 camaro sc
Re: vss help
thanks guys apprciate the help
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
