Pinion seal replacement question
Old Aug 4, 2008 | 07:50 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The pinion seal on my IROC is leaking. It's an 85 IROC with the stock 10 bolt. To replace the pinion seal my service manual shows a GM puller being used to separate the yoke from the pinion. Is a puller really necessary or will this thing usually come off without drama once the nut is removed? If I do need a puller, has anybody used a more generic puller or is the GM part required?
Old Aug 4, 2008 | 05:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Pinion seal replacement question
you need to make the nuts and count threads ect to mack sure the nut goes back on with the same preload as when it came off.
With the nut removed, mine came right off, maybe a tap with a hammer if its stuck a bit. No special tool required
Old Aug 6, 2008 | 06:38 AM
Pat Hall's Avatar
It's crucial that you get the nut tightened back EXACTLY where it was before you removed it. I usually count how many threads are sticking out of the end of the nut, then take a hammer and a sharp chisel to put a corresponding mark in the nut and the pinion threads. Yeah, a few love taps with a hammer will usually get the yoke off. Make sure to smear a small amount of gear lube on the rubber lip of the new seal before you put the yoke back on. If you don't, friction can burn the lip and cause it to leak again. Also, a 2-1/4" to 2-1/2" exhaust pipe adapter from the parts store makes a great tool to drive the new seal in. It clears the end of the pinion shaft, drops right into the metal recess of the new seal, and you just use a hammer to tap around it and drive the seal in place.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
