REAR PROBLEMS
Old Nov 4, 2000 | 09:45 AM
APCAMARO's Avatar
REAR PROBLEMS
IF THE # OF BOLTS ON THE COVER MAKE IT A NINE OR TEN BOLT...MINE HAS 10 AND I WAS WONDERING IF IT WAS POSI OR NOT? IF IT IS I THINK IT IS GOING OUT AND I WONDERING WHAT IT INVOLVES TO REBUILD IT?
Red 87'Z-28 350 tpi,MSD ignition 6al,gutted maf and airbox,
700r4 w/b&m shift kit and cor. servo
Old Nov 4, 2000 | 02:23 PM
ede's Avatar
ede
if it's not posi what do you think your problem is? if it is the posi to rebuild it all you have to do is replace the clutch disk in it.
-=ICON MOTORSPORTS=-
Old Nov 5, 2000 | 02:30 AM
Novaguy76's Avatar
To tell you the truth what makes a rearend a 9, 10, or 12 bolt is the bolts that hold the ring gear to the carrier. It is just by coincidence. The 9 bolt does have a 10 bolt cover though.
Old Nov 5, 2000 | 02:31 AM
Novaguy76's Avatar
To tell you the truth what makes a rearend a 9, 10, or 12 bolt is the bolts that hold the ring gear to the carrier. It is just by coincidence that the cover bolts are the same number. The 9 bolt does have a 10 bolt cover though.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
