Drive Line Vibration
Old Nov 5, 2000 | 08:06 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I am getting a pretty good drive line vibration around 2300-2500 rpm with my ZZ4/700R4 combo (700R4 is from a 92Z28) First, I just had my driveshaft balanced trying to track down the problem so we can rule that out. The vibration is very noticable when I keep the car in 1st or 2nd gear and bring the rpm up to the 23-2500 range. I do have an aftermarket Torque Converter, a TPI 2025stall, could the TC be bad? I had a TC go bad on my 91 Z28, gave a a cyclic vibration around 85mph plus. Dealership found a collapsed vane inside the converter.
Any ideas appreciated.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Nov 5, 2000 | 12:25 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Hey Rob...I had a similar problem it turned out to be the harmonic balancer on the crank. The rubber was bad you could see it was broke and sticking out from the metal.
Good luck!
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Nov 5, 2000 | 05:24 PM
Rob P's Avatar
Engine: ZZ4TPI
I'll look at the balancer but the ZZ4 was new and only has about 15,000 miles on it.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
Amillionoh7
May 24, 2020 08:01 AM
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
