Metric 200c Question
Old Aug 5, 2008 | 11:59 PM
ndamron's Avatar
Car: 82 Trans-Am / 83 Trans-Am
Engine: Major Mod SBC / Minor Mod SBC
Transmission: Major Overhaul 700R4 / Stock 700R4
Axle/Gears: None!!! / 3.73 posi disc...soon
Hey all,
I have an 82 T/A with the carb and metric 200c trans. I ripped off all the emissions stuff, and pulled the ECM and harness out of the car. I am swapping the ECM controlled Distributer for a vacuum advanced on and all that. My question is, while taking out the ECM control harness for the Q-Jet and Distributer, I cam across two wires that lead down to the trans, in doing some research on the Metric 200c i found that they have a lock up converter that was computer controlled? Being only a 3-speed trans i found this odd, anyways what's a guy to do in order to correct this problem, i don't intend on swapping out the trans anytime soon since it works great.....and suggestions?
Nick
Old Aug 6, 2008 | 12:05 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Metric 200c Question
The lock-up function isn't as important on a non-O/D transmission. If you wanted to keep it, you could figure out a way to control it the same way you would for a 700R4.
Old Aug 6, 2008 | 12:06 AM
ndamron's Avatar
how much will this shorten the life on my 200c?
Old Aug 6, 2008 | 12:10 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It won't really shorten it at all.
Old Aug 6, 2008 | 12:12 AM
ndamron's Avatar
awesome, cause i left the two wires chillen in the engine bay in case id have to futz with it, what difference will i notice as i drive it since it doesnt lock up, will i even notice anything?
Nick
Old Aug 6, 2008 | 12:56 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Probably not a whole lot.
Old Aug 6, 2008 | 10:45 AM
ndamron's Avatar
thanks much for the input!
Old Aug 16, 2008 | 12:52 PM
sroka's Avatar
Alot of super stock guys run that 200 trans.
Old Dec 10, 2008 | 03:06 PM
rodrob1961's Avatar
Car: 2003 SILVERADO /86 IROC/85 S10
MY CONVERTER DOESN'T LOCK UP. I NOTICE HIGHER RPMS AT CRUISING SPEED AND WORSE GAS MILEAGE.
Old Dec 12, 2008 | 02:32 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Not for long they dont. They only run it because its light, and they usually swap it out every run or two when it fails.
Shame on you. *cough cough*
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Aug 6, 2015 09:03 AM
