Borg Warner 9 bolt Cover
Old Aug 7, 2008 | 07:32 PM
beauimpala's Avatar
Point me in the right direction.
I've got a 87 IROC that has a rear end problem. Transmission shop says I need a Borg Warner 9 Bolt Cover 3.45 Ratio Carrier Posi. He says he can't find one through his distributors. I need one bad. Let me know who I can order one through.
Thanks.
Beau
Old Aug 7, 2008 | 08:09 PM
TMZIrocZ350's Avatar
Car: 89 IROC
Engine: 5.7L
Axle/Gears: 3.70
Re: Borg Warner 9 bolt Cover
If you just need the cover I would say that a junkyard would be the best place to look. I have not seen a place that sells the stock covers, but you can get one like this. http://www.hawksthirdgenparts.com/in...OD&ProdID=1674
This cover/girdle is a lot better than stock and will keep that diff in one piece a lot better than the stock one.
Old Aug 8, 2008 | 06:29 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
If you need a 3 series carrier then you might be able to find one on here otherwise you will have to look on ebay or contact hawks or somebody else that parts out a lot of 3rd gens
Old Aug 11, 2008 | 09:31 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
do you need a new rear end? i have a BW 9 bolt that was fine except for the slipping posi. Im not sure if you need the carrier, or the cover? if you need a cover, just get the one from TA performance, it will save you the pain of finding one.
theshackle
Sep 17, 2020 08:26 AM
AussiePr0nCar
Mar 6, 2020 04:04 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
fasteddi
Sep 2, 2015 10:29 AM
