TH700R4 question?
Old Nov 12, 2000 | 05:04 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
TH700R4 question?
I have an '86 IROC with a TH700R4 that has some internal problems,metal in the pan,etc. I have another TH700R4 from a '91 camaro 60degree V6.Irealise that the cases are different.But are the internal parts (the rotating stuff especially)interchangable?
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter. 9bolt 3.27 w/1LE rear brakes 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc
Old Nov 12, 2000 | 05:13 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes they are. There is rumor that the foward sprag in the V6 is weaker, but everything else is the same. However, you will have to keep your valvebody. There were changes to the case to accomodate for the auxillary valvebody wich your '86 doesn't have, but the internal hardparts/clutches are OK to use.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims.
'97 Bonneville SSE
Old Nov 12, 2000 | 09:37 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
I think youd be better off just getting a rebuild kit and save yourself the stress of pulling the trans out again
Old Nov 13, 2000 | 05:25 AM
ANDYZ28's Avatar
Car: 1982 Z-28
you may be right.where is the best place to get a rebuild kit? i can get GM parts at near cost.and have a friend who is a mgr at advance.
Old Nov 13, 2000 | 07:10 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
I wouldnt pay more than 125 for steels and clutches, If you can get one from chevy- that would be best
Old Nov 14, 2000 | 09:10 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I agree; get new internals if you're going to go that far. You can get a B&M "Super Rebuilt Kit" for about $300, they also sell a cheaper one which has no instructions.
You can find normal rebuild kits from online stores like http://www.carparts.com , http://www.wrenchhead.com , http://www.expressautoparts.com , and etc. In fact if you go through http://www.yahoo.com and search for "Carparts.com Coupon", you can sometimes find great online coupons! I had one for $50 off a $100 order.. bought $110 worth for $60.
If nothing else, those places can give you part #'s and prices to bring to your advance auto friend.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 14, 2000 | 07:38 PM
GeneralHazzard's Avatar
northern auto has rebuild kits for $99.99
Cleotiz
Jan 6, 2018 08:56 PM
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
