Won't start because of Tranny??
Old Nov 15, 2000 | 07:00 PM
rez_rat's Avatar
I drove my 89 Camaro RS/MT 60 miles this morning, and noticed some pretty nasty slippage going on along the way at lower RPMs when I tried accellerating. I parked it at the end thinking I needed to put some fluid in later today.
Well, it's later today, and now it won't even start! Are these two related in any way??
<waiting for my ride>
Old Nov 15, 2000 | 07:20 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
No, a slipping tranny won't cause a "no-start".
When you say "RS/MT" I am to assume that you have a Rally Sport with a Manual Transmission, how do you figure that it needs fluid if it is slipping?
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Old Nov 15, 2000 | 07:27 PM
rez_rat's Avatar
Whoops, forgot to mention that when changing the oil last weekend I noticed a leak.
Old Nov 15, 2000 | 07:32 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Low fluid will not cause a manual transmission to slip. You probably have a burnt clutch.
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Old Nov 15, 2000 | 07:57 PM
rez_rat's Avatar
Hey, there used to be a sound like an electric motor from under the body when the ignition switch was turned on, prior to starting...that sound is no longer there. Is, or should I say 'was', that the fuel pump?
Old Nov 15, 2000 | 08:08 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If your car still runs, probably not. It may be the fuel pump relay, but not the pump. If it does not run, then yeah, probably the pump.
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Old Nov 15, 2000 | 08:20 PM
rez_rat's Avatar
Crap. I'm beginning to think the pump died on me, and the sluggishness/"slippage" I thought was the tranny/clutch was actually the fuel pump on it's death leg.
Man, oh man. Isn't that thing actually IN the tank? I'm not driving it home for a while, then.
Old Nov 15, 2000 | 10:09 PM
Chrome's Avatar
Car: 92' RS Camaro
Yeah, your right it's in the tank. Not too hard of a job but I dropped my tank with the exhast system removed because I hadn't installed it yet. Just gotta drop the rear end down (watch the rear brake line that goes into a T at the thirdmember) and then undo your fuel lines and two bolts hold the straps in place. Took me about 30min to drop. Longer to put up cause that gas tank is a pain to weasel around. Good Luck
1985 Camaro
74' 355 Small-Block
Doublehump Heads
Holley 750DP 4160
Edelbrock Performer
BlueRacer Cam 232/232
Keith Black Pistons
700R4 w/ B&M Shift Kit
B&M Megashifter
camaro11j
Sep 19, 2018 08:49 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
drathaar907
Aug 6, 2015 04:20 PM
