t5 is half out, need help
Old Nov 20, 2000 | 05:51 PM
bleak's Avatar
Here's what we've done:
* cross member out
* clutch linkage out
* flywheel guard bolts out (the small 10 mm ones that hold in the metal guard)
* two bolts on each side bellhousing for a total of 4 bellhousing bolts removed
That sounds weak. It's cold as ***** out here.
Anyway we have yet to do the long black brace thing, we have the two large bolts started.
What is left? Just the u-joints (after we take off the brace by the driveshaft) ?
Are there only four bellhousing bolts? Or are there six? If there are six where are the other two?
Thanks.
Old Nov 20, 2000 | 06:21 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
bleak,
I hope you are refering to the torque arm when you talk about the "long black brace thing", that is what it should be and you do not have to take the two long bolts out at the rear end. Just loosen the mount off the side of the tranny by taking the one bolt out at the top of the mount.
There are six bellhousing to block bolts. Two will be on either ide at the bottom, the next two will be about half way up the bellhousing side. The last two are almost directly above the middle two if its a V8, if it's a V6 they are going to be very close to gether at the top of the bellhousing. On the V6 I have found it for me to be much easier to get to these two by going through the engine compartment. You will see them right underneath the distributor.
One thing I have learned in the past. If it is a V8 you need to remove the tranny first from the bellhousing. Then remove the bellhousing. If it's a V6 you can bring down the entire tranny with bellhousing. Don't ask me why that is, its just been one of my past experiences.
HTH
Old Nov 20, 2000 | 08:20 PM
bleak's Avatar
Well I thought that was the torque arm, but I didn't want to say that and look stupid if I were wrong. I don't have to remove the rear bolts, huh? That's cool.
It's a v6, btw, I apologize for not being clear about that.
I do have to unbolt the ujoints, correct?
[This message has been edited by bleak (edited November 20, 2000).]
Old Nov 20, 2000 | 09:57 PM
CHCKLS's Avatar
Engine: 409 SR
Yes, just ubolt the two caps (4 bolts total) at the rear that hold the ujoint in place at the diff. You will be able so slide the other end of the driveshaft right out of the tranny.
HTH
Old Nov 21, 2000 | 09:34 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Here's something useful about getting the driveshaft out-
https://www.thirdgen.org/messgboard/...ML/002848.html
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 21, 2000 | 02:03 PM
MikeS's Avatar
doesn't look like anybody answered this part yet...
there are four bellhousing to tranny bolts (unless i am stupid and can't remember anymore)
Old Nov 21, 2000 | 08:41 PM
bleak's Avatar
Well, it's out Thanks for all your help.
Old Nov 21, 2000 | 08:46 PM
hektyk's Avatar
Thanks for your help guys. Now I hope we can get it back in
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
FormulasOnly
Jul 23, 2018 08:47 AM
fasteddi
Exterior Parts for Sale
Sep 29, 2015 04:30 PM
drumstixer
Sep 29, 2015 03:02 PM
Damon
Sep 26, 2015 04:29 PM
