Can someone explain this cyberdyne box?!?!?
Old Nov 22, 2000 | 04:47 PM
Birmass's Avatar
I've got the cyberdyne speedo calibration box for my 6-speed. I'm not exactly sure what wires to connect to make this thing work. The directions are kinda understandable, but I really don't want to fry anything. Thanks.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
Eats LS1's with a 2.73 open rear and 2 1/4 stock catback
My Formula
Old Nov 22, 2000 | 08:03 PM
Birmass's Avatar
Freakin crap!! How do I hook this thing up!!!
Old Nov 22, 2000 | 08:13 PM
automanbuilder's Avatar
I have an 88 Firebird with a cyberdine calibration box 9902 on it. I called the techs at Cyberdine and he explained how to hook it up. I looked at my Firebird to double check. It wires as follows. The purple wire is the signal wire to the ecm. You want to splice into the purple wire. Attach the white wire to the speed sensor connector. Attach the blue wire(they said to try the solid blue wire first. If it didn't work right try the blue wire with a black tracer)of the calibration box to the purple wire going to the ecm. The black wire of the calibration box goes to the ground. To adjust the speed on the calibration box, the adjustment screw on the left is for coarse adjustment(for being bad off). Adjust in close. Then the adjustment screw on the right is to fine tune it. Clockwise decreases. I've had it on my car for about six months and have had no problems. If you have any questions, call the techs at Cyberdine. I had to call Jeg's (1-800-345-4545)to get the number to Cyberdine(IT'S NOT TOLL FREE). Hope this helps.
Old Nov 22, 2000 | 08:18 PM
Birmass's Avatar
THANK YOU!!!!!!! That's exactly what I needed!!
Old Nov 23, 2000 | 04:28 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Hey automanbuilder... I was wondering if your speedo jumps around on you a little?. With my car the speedo bounces up a little when I'am going 50mph or less and down at 80mph or more, also it does'nt move tell I'am going about 7mph. I have noticed the speed/density cars have no problem but they also have no speed sensor buffer. I have the 9902 box hooked up like you said so do you or anyone else think its my box thats not working or is this a common problem? BTW is your car TBI or TPI?
89 GTA 350 5-speed
(Jet hot coated) SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,jet chip stage 2,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,MAT relocation kit,free mods.
G-Tech times
0-60 5.3s
E.T. 13.91@104.8MPH (2300ft)
Old Nov 23, 2000 | 07:44 AM
My speedo jumped around some but I finally got it adjusted out with the fine adjustment on the box.I had a hard time getting mine adjusted.I tried both of the blue output wires on mine and seemed like one of the bounced around worse than the other.Which blue wire are you using?I had to use the solid blue wire.I had just about given up on mine ever being right but I finally got lucky with the adjustment screws.
Old Nov 23, 2000 | 01:12 PM
Birmass's Avatar
Mine was acting funny too. It doesn't register till about 5 mph, but when I first start the car up or let it sit idling and put my foot on the brake the speedo jumps all around. Wierd. Is it the 12volt source I used?? I tapped into the reverse light wires so I could put it by my shifter. Other than that, when my foot is off the brake it works fine.
88 firebird formula
350 Vortec TBI
Edelbrock headers
SIX-speed
My Formula
Old Nov 23, 2000 | 02:36 PM
Tony89GTA's Avatar
Car: 89 GTA
I'am useing the solid blue wire, but no matter what I do it does'nt fix the problem. I think I will change the speedo gears over the winter and be done with it.
Old Nov 24, 2000 | 04:05 AM
I had comverted my car a old 4 speed muncie so my stock sender wouldnt fit . I had to buy the matching cyberdyne speed sender. That might be the diffrence . hope I still might of helped .
Old Nov 24, 2000 | 06:04 PM
Birmass's Avatar
Hey, I'm still trying to figure this thing out. If I'm idling, the speedometer jumps around like crazy sometimes. Does anyone have an idea as to why? I'm using the solid blue wire, maybe I need to switch to the other one. Any ideas??
One more thing - I have it hooked up to the reverse light wires for a 12volt supply, but that shouldn't effect it, right??
88 firebird formula
350 Vortec TBI
Edelbrock headers
SIX-speed
My Formula
[This message has been edited by Birmass (edited November 24, 2000).]
Old Nov 24, 2000 | 07:07 PM
It might be your power source.Mine is connected in the fuse box to the accessory fuse. If thats not it I would check the ground wire for a loose connection.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
