torque arm?
Old Nov 30, 2000 | 04:49 PM
Fastcamaro87's Avatar
torque arm?
ok im gonna do my tranny swap pretty soon, although it seems that everyone has a different opinion on the torque arm, what should i do about it, should i just unbolt the mount from the tranny or should i remove it completely while im doing the tranny swap? whats the best way to handle it? thanks in advance for everyone`s help, I love this board.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Nov 30, 2000 | 04:53 PM
Blade's Avatar
You GOTTA have the torque arm no matter what. Otherwise your rear-end is gonna move all over the place... especially when you drag race.
Old Nov 30, 2000 | 05:01 PM
ede's Avatar
ede
if you're doing a r&r on the trans just unbolt it from the trans mount while you do the r&r. as you were told before you can't leave it off.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 30, 2000 | 05:24 PM
duh no**** i have to keep it. its a vital component to my suspension. i just want to know the best way to remove it or get it out of the way while im putting in my new tranny.
Old Nov 30, 2000 | 06:35 PM
merf23's Avatar
i always pull it off when i R/R the trans, but i have a lift and air tools so it only takes a minute to remove. Ede says it doesnt get in the way if you leave it hooked to the rear and i dont doubt him for a second.
Old Nov 30, 2000 | 06:36 PM
Blade's Avatar
Well I think it's a NO brainer on how to remove it. It only has two attaching points. The two bolts that bolt up to the differential. Take em out, slide it out and do your work. DOH! lol
[This message has been edited by Blade (edited November 30, 2000).]
Old Nov 30, 2000 | 11:01 PM
Blade i know how to remove it, my question is if it is neccesary to take it out completely, or just disconnect it from one end. and if it is in the way while trying to remove the trans.
Old Dec 1, 2000 | 08:12 AM
82camaro's Avatar
Car: 82 camaro SC
Just remove it from the tranny, you don't need to take it completely off.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Dec 1, 2000 | 09:22 AM
merf23's Avatar
Before i remove the torque arm, i put a floor jack under the panhard bar mount on the LR of the axle to stop the axle from rotating when i remove the bolts.
Old Dec 1, 2000 | 10:57 AM
thanks to all of you who provided me with useful information.
Old Dec 1, 2000 | 12:25 PM
327 firebird's Avatar
I've must have done this a millions time and all different ways. The best way I've found is remove the 2 bolt in the back, slide it out of the mount and THEN when ready to put it back in put a jack under the rear. It will spin a little when the arm is removed but once you put a jack under it and start jacking it will straighten up. Just jack it until the rear is straight it shouldnt move the car up much. This way you don't have the arm or jack in the way until its ready to go in and you dont have to fight with the arm and rear to put it back in. Hope this helps
Old Dec 2, 2000 | 02:04 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
should you remove the springs before removing the torque arm?
aka:15 year old camaro freak
owner of a 91 z28 5.7l camaro
Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Trans Go Shift Kit, 2k Stall, B&M Rachet Shifter, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Dec 2, 2000 | 09:02 AM
Well if you do it the way I decribed removing the the springs is not necessary and a waste of time
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
