9-bolt BW rear wheel bearing,,,need help on replacing ASAP!!! SOMEONE HELP!
SubscribeHi i have a borg warner 9 bolt rear,,,i have just discovered i have a bad wheel bearing. Does ANYONE know how to replace one of these. Is it similar to a ford rear where the bearing is pressed on the axle and does it require takin the cover off?...I am planning a trip on sat. and dont trust this,,,ANYONE please help ASAP!!!,,,,thanx
86 Trans Am,T-Tops,305tpi,7r4(rebuilt w/shift improvments&added clutches,9-bolt(2:77:,flowmaster,3" cat back,,,otherwise completely stock
You do not have to pull the cover off. The rear brake has to be removed and the four bolts that hold the bearing in th housing have to come off. Once the bolts are off tap on the axle and it should pull out. The bearing will have to be pressed off the axle.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
yeah what he said......
i just pulled mine apart for the rebuild that everyone says can't be done....they're a cake walk!!
Hey Quartermileguy - i live in Griswold....have any parts yuo want to swap?
1984 L69, IROC look, tangerine orange
305 from 87 IROC, tossed peanut cam,
replaced with LT1 cam.
Uses gas as fast as i can pump it!
Actually, the bearing will have to be cut off the axle. The new bearing and seal will have to be pressed on. Make sure you get the correct seal. There is a specific right side seal, and left side seal.
I highly recommend you find a shop qualified to do it right, or you will be doing it again.
merf --- i've got a whole shwack of parts....let me know what you need....i have an 88 iroc that i wrecked and an 84?? firebird for parts....
quartermileguy@hotmail.com
Quartermileguy...i am looking for a nice set of seats and a few odds n ends.
merf23@yahoo.com
thanks
sean
merf23@yahoo.com
thanks
sean
if that '84 has a manual console I'll be happy to take it off your hands,you could have my auto once I do the swap.
