Type F tranny fluid in a GM automatic
My TH200-4R rebild is approaching 100,000 miles and it just now starting to shift a little sloppy. The Dexron fluid is clear red and smells O.K. Will Type F or B&M TrickShift firm it up? Will putting Type F in make things wear out faster? I want to keep the Olds alive a little while longer. I keep it around to get parts, tow trailers, and other pack mule jobs. There's nothing like driving a big beater on a dirt road, either!
yeah i was wondering about this one too. i heard it will make you shift harder, now what i was wondering if i would have any improvement if used in a manual tranny like a t-5 that uses dexron, would there be any improvement?
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
don't think it would matter in a manual trans. type f is made for ford, as we all know ,because ford uses les clutches in their automatics so they need something that will not slip as much as dextron would.
-=ICON MOTORSPORTS=-
1st & 3rd
1st & 3rd
1989 Camaro RS LO3 WCT5 "The Hose Queen" 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
Transmission: 4L80E/4L80E
Changing the fluid and filter is the conventional 1st step to fixing any auto tranny problem. I wouldn't say that the change to Type F would be the right answer for you, though.
actually my T-5 manual transmission calls for dexron 2 or equivalent, it doesnt say to use gear oil.
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
The T-5 trannys that use ATF are called "World Class" transmissions. Rougher, tougher, more heavy duty!! I just bought one.
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
What would the effects of Type F be on a 700R4 or a 200R4? How about long term use? Is it good for the transmission or bad?
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-Future:
-383 Stroker?
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Future:
-383 Stroker?
If you want a REAL ATF, use AMSOIL synthetic. It is rated as both Dextron and Type F, and gives lubrication and temperature benefits that you will never see with petroleum-based ATF, whether Dextron or Type F.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Using type f won't hurt your tranny at all. There is a federal mandate that all trans fluids must be compatible. The major difference between type f and dextron is that F has a higher coefficient of friction than dextron which initiates clutch lockup quicker. I plan to use f in the 200 that will go in my car. To clean up sloppy shifts you can put in a shift kit but it is on it's way out.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
is it true that the world class t-5`s use dexron II and that the earlier t-5s use gear oil? cause my 87 calls for dexron, and i thought that they didnt start using the EC t-5 until 88 ,
The type "F" was designed for use with Asbestos clutches, the type found in Ford till 1977. From then on paper type clutches are used in everything. According to Borg Warner, Raybestoes, & Hydramatic, the type "F" fluid has apx. 12-17% less holding power on dynamic clutches and bands when compared to approved Dexron 3. Ford type "F" has more static holding power,(neutral to drive) but this is not a problem with any 700R4 or 2004R transmission. When GM transmissions come in that have ran type "F" fluid, we have seen faster wear on parts. I would stay away from type "F", B&M Trick Shift or equvilant. If you like synthetics use Amsoil (best) or Red Line (2nd best).
Hope This Helps!!!
Hope This Helps!!!
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Originally posted by 327 firebird:
Fastcamaro, yes it is true that earlier t-5's used gear oil and later ones used dextron II or better. According to my chiltons 1982-1984 used gear lube and 1985 and up used dextron II.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Chevy Info --> MadMike's
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Hello, Michael
Sep 11, 2015 01:10 PM
