For all of the DIYers w/ auto trans
Old Dec 10, 2000 | 07:50 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Here is a blunt, step by step way to adjust your TV Cable. I see alot of people don't know what it is let alone how to adjust it. If you don't know jack about transmissions, please do not deviate from this procedure, or do anything else not mentioned.
Step one: Locate the TV Cable adjuster (see picture) If you don't have TPI, the Carb and TBI will have a similar looking cable.
Step two: Push the "D" shaped button all the way in to release the locking mechanism. You can't be a sis about it, you have to push hard.
Step three: Push the cable retainter all the way in untill it bottoms out. This must be done while the "D" button is still pushed in.
Step four: Rotate the throttle by hand untill the retainer ratchets out. Once again, don't be a sis about it, crank hard on the throttle. Also, don't do this from the accelerator pedal. You must do this from the actuall throttle.
Thats it. Don't do anything else. Don't pull on the cable for "one more click" because it doesn't prevent "WOT" like many people think.
I hope this clears some of the confusion up.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Dec 11, 2000 | 03:18 AM
Black Missile's Avatar
Awesome!!!!
Finally, a straight no nonsense way to adjust the T.V. cable. Even with pictures!
To the administrators of Thirdgen.com: How about copying that post and including it into the tech article section on the site?
That definitely should be added as an article in the tech section.
1989 Firebird GTA: black on black 5.7 liter (N10 dual exhaust) with T-tops and leather.
Old Dec 11, 2000 | 06:46 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I whole-heartedly agree, this SHOULD be a Tech Article...hopefully people will start to read some of those articles. There are some great ones in there...and this is another example of a great one.
Thanks GMTech.
Old Dec 12, 2000 | 05:19 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
GMTech, that is a great article (Tech Article, hint, hint ). One thing though, I (IIRC) think my 1984 GM Service manual (aka Helms) says to depress the accelerator and not use the throttle linkage (on the carb) to set the proper position. I used to do it the method you described (still do), what do you think?
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Chevy Info --> MadMike's
Old Dec 12, 2000 | 06:44 PM
Josh 91RS's Avatar
how can you tell if your tv cable needs to be adjusted or is it just something that needs to be done on a regular basis???
Old Dec 13, 2000 | 01:26 PM
Biochem's Avatar
Car: 2002 SOM z28
The Holley guy said that you need to do it via the peddle too... I will try it that way tonight, because the way you described (and I used to do it that way too!) is causeing my car to shift wrong.
Or at least I hope that is the problem following the carb swap...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Old Dec 13, 2000 | 04:13 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Both ways will come very close to the same adjustment. My GM Service Manual says to use the linkage, not the pedal.
If a TV's been mis-adjusted for a very long time, when it returns to the "correct" adjustment, the tranny will act funny. I set my friend's Monte Carlo's (200-4R trans) TV cable by-the-book, since his tranny was shifting funny. Well on the test drive, it started really acting up, late shifts, banging into gear, etc! We went back to my house, and I put it back to where it was. (I thought I was going to be buying him a new trans... yipe!)
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 13, 2000 | 04:22 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
wow! the hand of god! did you guys see it?
hahaa thanks GM tech, you rock. one thing, you just tighten the TV cable as far as it can go? or is there some specific amount of tightening?
thanks!
Old Dec 16, 2000 | 09:15 AM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
Excellent post, thanks. I followed this procedure and it took about a minute to complete.
Listomps11
May 9, 2014 01:56 PM
jwright32
Aug 23, 2010 08:42 PM
