Shift kit for v6 700-R4's the same a v8 700R4's??????
Old Jan 2, 2001 | 04:40 PM
z28cam100's Avatar
Car: 89 Trans Am GTA
My friend has a 2.8 87 camaro and wants to install a shift kit. Is there difference bewteen the v8's tranny shift kits and the v6 tranny shift kits?? Any help will be appreciated.
86 Camaro
305, T-tops, flowmaster exhaust, B&M shift kit
"Real cars are built, not bought"-some smart guy
http://hometown.aol.com/z28cam100/index.html
Old Jan 2, 2001 | 04:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I can't see why it would be different.
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 383 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
Old Jan 3, 2001 | 10:30 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Apeiron's right; there's no difference. I put the B&M kit into my v6's 700r4. In fact, I don't think companies put "v8" or "v6" in the descriptions for their shift kits...
There's a few internal differences between a v6 and v8 trans; but a shift kit won't touch those... only a rebuild kit would, and you'd have to drop the trans to get at them.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jan 3, 2001 | 03:33 PM
z28cam100's Avatar
Cool..thanks!
I knew that the bell housing had a diff. bolt pattern but i wasn't sure if there was other stuff that wouldn't work.
86 Camaro
9T1 Z-28
Mar 28, 2007 10:30 PM
SheldonZ28
Jan 10, 2007 07:19 PM
1320 Right Ln.
Sep 27, 2004 10:29 PM
Thirdgeniroc
Jan 2, 2004 03:50 PM
IROC-JP
Feb 8, 2001 08:42 PM
