How Do I Build a 700R4, STRONG
Old Sep 21, 2008 | 02:19 AM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
1st off i dont need to hear put a 5 or 6 speed or a TH350 in it
THANKS!!!
anyway, i have a 700r4 that was "built for the drag strip and to hold a big motor" ........ i was kickin, it would lay rubber out going into 2nd and all, shifted great and then one day it started to slip, TV cable is ok, fluid is bright red, not burnt, at proper level, not to hot also.......well ended up being the band, after only 8k .....$2k + down the drain
oh yea it seen the drag strip one time, and the motor is a mildly moddifed 305 TBI, with aprox 250hp (hey it beats the 170 stock number to hell and back )
anyway, since the "Pro" didnt do a good job tell me what i need to put in it to make it last, im happy with my valve body mods so im sticking with them, so like i said, please tell me what to put in it to make it last
Old Sep 21, 2008 | 06:41 PM
89RS_82Z's Avatar
Re: How Do I Build a 700R4, STRONG
BUMP, need it rebuilt by Oct 9th
Old Sep 21, 2008 | 06:59 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I can already guess the answer will be buy one from someone that is on this board.
I did. It didn't last either.
Best of luck.
Old Sep 21, 2008 | 07:11 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
I'll be honest with you this is the way I am going to go. I have done a TON of searching and research on this and I can't find a better deal or product anywhere. I am going with Mad Dog Louie from Outlaw Transmission. These may not be what you need, but just give him a call!
These are his eBay links, but he does have a website as well. Call him!!!
OPTION 1:
This one is a level 2:
http://cgi.ebay.com/ebaymotors/ws/eB...m=290256515016
This one is a level 3:
http://cgi.ebay.com/ebaymotors/GM-70...mZ290261668920
OPTION 2:
I have spent a lot of time talking with PATC Raptor Transmissions and others like them and they produce a phenomenal product as well. You can call them and they can guide you in purchasing a kit and then you need to find someone qualified to rebuild it.
Old Sep 21, 2008 | 07:56 PM
89RS_82Z's Avatar
yea i have always been interested in raptor, they seem like kick a** and walking the dog.................but so was the guy that built mine, people swear by his 700's..............maybe he got a defective part?!?!?!?!? im going to talk to him monday, see what he says, if its not what i want to hear well thats his own problem, because i have a few freinds that want him to build their trans
hopefully someone has done one themselfs or got the parts and had someone build one, that way i know what way to go.....and it hopefully work this time
Old Sep 22, 2008 | 03:53 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
You have a 305 TBI. A stock trans would be fine.
You don't need anything built STRONG...you just a competent builder.
Old Sep 22, 2008 | 03:56 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
What mods are done to that 305 tbi to get those numbers you are claiming?
A stock trans should live all day behind a mild 305tbi.
Old Sep 22, 2008 | 06:07 PM
gmpptech's Avatar
It could be a couple of things. First was your converter clutch coming on? If it wasn't, it can cause burned bands and 3-4 clutches. Could be just a faulty brake switch. Second did you flush out the old fluid from your cooler and lines? Next, the builder make not have checked band pin apply length properly. There are three different pin lengths to choose from and you need the special kent-moore tool to do so. There are many other posibilities, but those are most common. Also did you check line pressure, may have been low for any number of reasons. You shouldn't be burning this trans with those power levels. If you want to make it more durable next time you can apply more pressure to the band by getting performance servos. Alto also makes extra wide bands in their red eagle line, which you will have to use with a new reverse drum do to dishing from the old band. Hope this provides some insight.
Old Sep 22, 2008 | 06:28 PM
89RS_82Z's Avatar
stock trans is not good for a briggs and straton, it a sloopy shifting pile of trash
anyway, its the clutch pack i know that, i just want to know what to put in it this time so it will hold, im planing on putting about a 330 HP motor in it down the road............. i want it to be over kill, i do not want this to happen again...8k off of a build that should of been near bullet proof is a joke
list of mods is more than i want to type, if you need anymore proof on the HP of this 305, put a stock or close to stock 350 TPI up to it.......but thats off the subject of what i want done to the trans
Old Sep 22, 2008 | 07:05 PM
8992guy's Avatar
Dude Ive had a stock 700 with shift kit for over 3 years behind a tpi 305 runnin 206 horse at the wheels before roller rockers and havent had a prob yet. Find a better builder
Old Sep 22, 2008 | 07:16 PM
89RS_82Z's Avatar
i know that much............................i want to know what people are putting in a 700 to make it hold, yes i know my 305 TBI shouldnt break it, i do not need to hear that one more time.......
all i want to know is a good company to get my parts from to rebuild it, one that someone with a well better than stock motor has got and has had good luck with
all i want is a bad azz trans that will lay out rubber going into 2nd like mine does, and last over 40k.....not 8k, and hold at least 350hp all day and night
Old Sep 22, 2008 | 07:18 PM
bob8703's Avatar
did the guy that build the trans for you give some kind of guarantee. i would get a hold of him and have him fix it. 8k out of that trans is bull. i would raise hell and get him to fix what is bad on it or maybe get some money out of him to have someone else fix it.
Old Sep 22, 2008 | 07:45 PM
gmpptech's Avatar
Here is where you can buy a good trans or the parts to make yours good
http://www.transmissioncenter.net/highperf700r4.htm
Old Sep 23, 2008 | 09:08 AM
Car: 1997 Corvette
Oh, well then, in that case, go spend another $2k on a STRONG trans for your 305 throttle body.
Old Sep 23, 2008 | 09:41 AM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
www.700r4l60e.com
Old Sep 23, 2008 | 09:44 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
you did tons of searching?????????? how did you miss this one then? https://www.thirdgen.org/forums/afte...ghlight=maddog
Old Sep 23, 2008 | 10:05 AM
dctrumpet's Avatar
Absolutely 100% aware of that thread. That is the very thread that caused me to do more research. That thread is also 2+ years old. I realize people were still having issues in late 2007.
I personally know 7 people with the Maddog transmission level 2 and level 3. They have run them hard the past year and have had ZERO issues with their transmission.
I was concerned when i read that thread because of the major issues people were having. I spent a good month online and on the phone and I am very satisfied and feel confident about making my decision. Who knows maybe i will get F'd in the end.
Old Sep 23, 2008 | 10:19 AM
dctrumpet's Avatar
Maddog almost sounds like an F-Body Motorsports situation... If you live close you get a great product and great customer service. If you buy online and live far away then......
Who knows. I have yet to buy one and I have spoke with him and discussed the very issues stated on TGO.
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
why do you want to chance it? why not Dana (Probuilt) transmission?
Old Sep 23, 2008 | 10:25 AM
dctrumpet's Avatar
I'll be honest with you, I have not purchased one yet. Since everyone is still this concerned about his work I may very well rethink the whole thing. I was hoping the guy had changed based on the good reports from my friends and others over the past year. Hmmmm.......
You can never go wrong with a Dana you're completely right.
Old Sep 23, 2008 | 11:43 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
How were you laying rubber into 2nd gear with 2.73's? I can't do that with my LT1 with 2.73's.
Old Sep 23, 2008 | 04:17 PM
89RS_82Z's Avatar
its a WAS bad azz trans, and its darn good lil 305, check out the video
http://myspacetv.com/index.cfm?fusea...deoid=26369651
and that wasnt even a good one......got other camaro vids in the mix to if you look at the other videos from user........got one of my loud azz air horns on there too
Old Sep 23, 2008 | 04:25 PM
89RS_82Z's Avatar
i had a 1 year warr. on it, and well its a little over a year and 8k miles, the guy who built it says parts are only warr. for a year, go figure.... i found someone else localy that will actually stand behind his work, 800 if i pull it thats also him buying the parts, he claims they are top end and way better than stock, he is also doing the shift into OD at WOT crap to..... i can also buy parts and bring them to him and he will do it for alot less
im going to check out the links
Old Sep 23, 2008 | 04:46 PM
pearlphoenix's Avatar
Car: 86 Trans Am
Engine: 383
Transmission: Probuilt 700r4
Axle/Gears: 2.77 BW 9 Bolt
i dont post much on here, but i will say good things about dana any time i get the chance, three years of abuse and still shifts like the day i got it
Old Sep 23, 2008 | 07:23 PM
8992guy's Avatar
Why does nobody say TCI Ive known plenty of people with em in there rides and no probs.My little brother got 1 and payed 1700 for it, shifts like mad.
Its behind a fresh 383 TPI so ill let u know when he passes 8k miles.Good luck
Old Sep 23, 2008 | 07:46 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Go with probuilt end of story. I have beat the hell out of my tranny and still shifts perfect, and says it will last up to 550 horse or so
Old Sep 23, 2008 | 09:56 PM
89RS_82Z's Avatar
pro built is http://www.700r4l60e.com/ , correct?????
Old Sep 24, 2008 | 12:52 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
yup that's it
Old Sep 24, 2008 | 08:08 AM
Aaron91RS's Avatar
Car: RS
Best of luck.
put it together.....
Old Sep 24, 2008 | 04:34 PM
89RS_82Z's Avatar
yea thanks for your helpfull insight, i will remember you when i send out my christmas cards this year
Old Sep 24, 2008 | 05:06 PM
Aaron91RS's Avatar
Car: RS
if you can't understand mine didn't last from that, then I don't think your going to be capable of sending out christmas cards.
Old Sep 24, 2008 | 05:21 PM
dctrumpet's Avatar
Aaron,
I get to St. Louis often. I am near Springfield, IL. Joe from Performance by Joe will be doing my dyno soon and I am having a father/son team do my custom 3" y-pipe. They are out of Festus, MO.
Just wanted to say Hello!
Old Sep 24, 2008 | 05:27 PM
89RS_82Z's Avatar
i take it you are sayin you had one from Dana that didn't last, at first it seemed like you were telling me to buy the dana and just for info some random trans you got on here went south
i will still send you a christmas card .....but serriously if your tring to say your dana didnt last im sorry for the mis understanding
if you had a dana what went south in it??? you know the total miles it had on it
Old Sep 24, 2008 | 07:03 PM
Aaron91RS's Avatar
Car: RS
Aaron,
If I don't already know you from team3rdgen.com go there and sign-up. That's where all the MO 3rdgen guys are.
It trashed itself so bad so quick that most everything was gone when it was taken apart.
~10,000 miles. Never saw the track. Never saw anything other then radial tires.
Did have a 406 in front of it and it probably just won in the end.
It worked perfect right up until it went though.
Old Sep 24, 2008 | 10:48 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I got mine rebuilt from a buddy of mine.
He used parts from TCS transmissions.
My 700r4 is holding up just fine.
Results in my sig
Old Sep 25, 2008 | 08:56 PM
89RS_82Z's Avatar
yea well the guy who built mine has never had any problems like this, even with drag strip cars, we are thinking i got a defective part in it that only held up for that long...... but the damage has been done, im going to this other guy, and he guarantees it will hold up.... he said i could get the probuilt kit, but he said what he has is just as good, so here we go, another 700 that is built to handle gobs of power, lets see if it can hold 250hp longer that 8k
Old Feb 28, 2010 | 03:50 PM
itisthepitts's Avatar
Since that thread is closed / I purchased mine from Outlaw in 2008 and got about 20 miles out of it. When my transmisson guy opened up the thing he musta laughed for 20 minutes. I would like to say it was a junk core but it was obviously worse. The trans had been pieced together with junkyard parts.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Whata69
Mar 2, 2016 06:34 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
earlpote
Sep 12, 2015 11:55 AM
Amillionoh7
Sep 11, 2015 11:36 AM
