swap 9 bolt for 10 bolt will hardware mount????
Old Jan 14, 2001 | 11:25 PM
89 GTA Dave's Avatar
I have a borg warner 9 bolt and having problems with it, I want to put in a GM 10 bolt but do not know if the caliper brackets will mount up the same? has anyone done this and if so what do I need or is it a direct bolt as long as the 10 bolt is disc brakes as well?
Old Jan 14, 2001 | 11:40 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
it depends, if your are going to install the PBR brakes 11.65 aluminum caliper, on a pre 91 ten bolt then you will have to get the backing plates for the 91-92 10- bolt from the dealer or yard. i don't have the part number. i JUST DID THE SWAP I DESCRIBED. i paid about 50 for the plates at GM. Otherwise the 88 and older disc set-up is the same back to 82. No plate cahnge req. (i think) good luck and if you need to explian more feel free. THE SHAGGY IROC
'89 SHAGGY IROC
L98 7r4, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc.
so much to do , so little money
Old Jan 15, 2001 | 12:43 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
As long as you put in an 89-92 10-bolt with disc brakes, everything will bolt right up. I went the other way, traded my 91 10-bolt 3.42 for a 89 9-bolt 3.45, for the strength.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 15, 2001 | 06:12 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
I swapped my '89 9bolt for an '88 10 bolt. As mentioned above, the backing plate is completely different. I tried to purchase the plates from 3 different dealerships before the last one told me that they were no longer being made. So I welded up the bolt holes on the '89 backing plates(ones that bolt up to the end of the axle housing), marked the '88's pattern on the plates and drilled new holes. I was able to retain the '89 up rear brake system and haven't had any problems with the 10 bolt's strength (crossing fingers and knocking on wood here ).
Sparks a flyin'.
1989 L98 IROCZ, Bored .030 over,400 Crank,Dart PRO 1 Heads 200cc intake,ZZ3/ZZ4 Cam,Crane 1.6 RR,Edelbrock 3860 Hiflo TPI Manifold, AS&M LTRs, Edelbrock 58MM TB, Ported Plenum, TCI Reverse Pat Man Valve Body, SVO 24# injectors,TCI Streetfight Stall Converter, 3.23 Gears on Auburn Pro Posi, Some Suspension Mods
Old Jan 15, 2001 | 08:57 PM
Eightyninef's Avatar
I'll buy your 89 9-bolt,just to play with. just the guts with gears. You'll need the brakes and hardware for your swap anyway
larryburd@mail.com
Terrell351
Jun 13, 2021 01:13 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
