Tranny Shifting too Early...Help
Car: 1986 IROC Z28
My 700R4 shifts through the gears really quick, like 25mph, 4th gear. I have to shift it through the gears manually. Will a shift kit help fix this? Any help would be appreciated.
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Re: Tranny Shifting too Early...Help
Adjust your TV cable, it's probably too loose.
You can find the procedure somewhere else on this site.
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
adjust your tv cable.i had the same issue awhile back when i swapped from a stick to an auto........had to get the proper throttle/tv cable bracket as well.now the car hammers
How will they affect (slow) shifting?
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Could be either.
If you have changed gear ratios, the governor is likely the culprit. But a slight rear gear change shouldne make it shift into 4th at such a low speed.
If you have messed with the TB unit, TBI unit or Carb (whichever applies) then probably you didnt reset the TV cable or did it improperly.
The governor could also be sticking. If so, I would do a fluid flush and refill with new fluid. B4 installing new fluid, remove the governor assembly, clean it with mineral spirits and make sore it operates freely B4 reinstalling it.
Other than that could be a biding or broken TV cable, come loose inside the tranny or the TV valve in the VBody had failed.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
